Is This Moment Generating Function Expression Correct?
The moment generating function expression presented is debated regarding its correctness, particularly in relation to the conditions under which it holds true. It is suggested that the expression is valid only if the moment generating function is exponential, aligning with a Taylor expansion. This holds for specific cases like a Wiener process but may not be applicable in general scenarios. The discussion emphasizes the importance of the underlying distribution when evaluating the moment generating function. Further exploration of the final form is encouraged to clarify its implications.
donutmax
Is the following correct?
M(t)=1+t\mu'_1+\frac{t^2}{2!}\mu'_2+\frac{t^3}{3!}\mu'_3+... =\sum_{n=0}^{\infty} \frac {E(Y^n)t^n}{n!}
where
\mu'_n=E(Y^n)
Mathematics news on Phys.org
I think that will only be true if your moment generating function is an exponential - in which case you are just doing a Taylor expansion. This is true for a Wiener process - but I don't think the relation you have holds in general.
Regards,
Thrillhouse86
<br /> m_Y(t) = E(e^{ty}) = \int e^{ty} \, dF(y) = \int \sum_{n=0}^\infty \frac{(ty)^n}{n!}\,dF(y) = \sum_{n=0}^\infty \left(\int \frac{(ty)^n}{n!} \, dF(y) \right)<br />
What do you get from working with the final form above?
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
