How Is Work Related to Heat in Thermodynamic Processes?
The discussion centers on calculating work and heat in a thermodynamic process involving a dilute gas. The work done by the gas is confirmed to be 19.2 kJ. There is uncertainty regarding the calculation of heat absorbed, with two conflicting approaches presented: one suggesting to subtract work from internal energy and the other to add it. The correct method is clarified as adding work to internal energy, leading to a heat absorption calculation of 74.4 kJ. This highlights the importance of understanding the relationship between work, heat, and internal energy in thermodynamic processes.
jagged06
One mole of a dilute gas initially has a pressure equal to 1.00 atm, and a volume equal to 12.0 L. As the gas is slowly heated, the plot of its state on a PV diagram moves in a straight line to the final state. The gas now has a pressure equal to 5.00 atm, and a volume equal to 76.0 L.
(a) Find the work done by the gas.
19.2 kJ [correct]
(b) Find the heat absorbed by the gas.
I'm just not sure if I would add Internal Energy and the Work, or subtract the work
Δ U = Q + W
E = (3/2) nR(T2-T1)
T1= (P1V1)/nR
T2=(P2V2)/nR
T1=((1x10^5)(.012))/R
T2=((5x10^5)(.076))/R
Here is where I'm not so sure:
is it Q= E-W
-> Q= 36 kJ
or Q= E+W
-> Q=74.4 kJ
Work done by a gas is positive, so you'd add it.
Correct, Thank you very much!
