Magnetic Field of a Slab - What Loops Can Help Solve This Problem?
Saraharris38
A thick slab extending from z=-a to z=+a carries a uniform volume current J=J (in the x direction) Find the magnetic field, as a function of z, both inside and outside the slab.
∫Bdl=(µ0)Ienc
I am not sure how to start this. Could someone explain why B is a function of z? Is this just a set-up for the question, or is B obviously a function of z? I also don't really know how to conceptually explain this problem. Thanks!
Well, for starters, magnetic field is a thing that exists all throughout space. Different points in space have different values of z. When you specify the value of magnetic field somewhere, you will specify that "somewhere" by giving a value for z (along with values for x and y). Thus B is a function of z.
I'm guessing what you meant to ask, though, was "or is B obviously a non-constant function of z?" But it doesn't say that. B could be independent of z for all you know. (The problem's wording does indeed suggest - but only suggest, not guarantee - that that is not the case.)
To start with, do you understand the meaning of the equation
\int \vec{B}\cdot\mathrm{d}\vec{l} = \mu_0 I_\text{enc}
? Well enough to conceptually explain it?
If you do, think about what sorts of loops you could draw that might be useful.
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
The value of H equals ## 10^{3}## in natural units, According to : https://en.wikipedia.org/wiki/Natural_units, ## t \sim 10^{-21} sec = 10^{21} Hz ##, and since ## \text{GeV} \sim 10^{24} \text{Hz } ##, ## GeV \sim 10^{24} \times 10^{-21} = 10^3 ## in natural units. So is this conversion correct? Also in the above formula, can I convert H to that natural units , since it’s a constant, while keeping k in Hz ?
