Estimate Power of CMOS Inverter Circuit - 0.12um Tech
To estimate the power of a CMOS inverter circuit using 0.12um technology, SPICE is recommended for simulation, provided you have the necessary modeling parameters from your IC process. Dynamic power is calculated using the formula dynamic power = Vdd² * CL * f, where CL is the load capacitance and depends on parasitic capacitance, including internal capacitances, wire capacitance, and load capacitance. Determining wire capacitance for a specific technology can be complex, but it typically involves consulting technology-specific resources or tools. Freeware options for simulation may be available, though specific recommendations were not provided in the discussion. Accurate power estimation requires careful consideration of all capacitance components in the circuit.
bilalarif
I want to estimate the power of a CMOS inverter circuit. I want to ask that is there any software for simulation purpose to give the power of CMOS inverter.
The second problem I have is that when you calculate the dynamic power of CMOS
dynamic power = Vdd2*CL*f
This dynamic power depends upon the parasitic capacitance . The total parasitic capacitance is equal to sum of internal capacitances of the CMOS + wire + load.
I am using 0.12um technology to implement my circuit. My question is about wire capacitance that how to determine the wire capacitance for given technology .
Welcome to the PF. You can use SPICE to simulate the inverter circuit. You will need the modeling parameters from your particular IC process, however. Those should be available to you -- you can generally get them from the IC fab vendor.
can u tell me any freeware for simulation.
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
