Understanding the Work of Gravity: Exploring Positive and Negative Forces
  • Thread starter Thread starter flynostrich08
    Gravity Work
When two massive objects are moved directly away from each other, the work done by the force of gravity is negative for both objects, not positive for one and negative for the other. The reasoning behind this is that gravitational force acts to pull the objects together, so moving them apart requires work against this force. If the objects were moved closer together, the work done would indeed be positive, as gravity assists in their movement. Therefore, the statement is false because the work done is consistently negative when moving apart. Understanding these dynamics is crucial for grasping the principles of gravitational forces.
flynostrich08
( True / False ) When two massive objects are moved directly away from each other the work done by the force of gravity between the objects is positive for one of the objects and negative for the other.
i believe the answer to be false because both will always be negative
Your reasoning is OK, but always? What if the objects are moved closer together?
