Force that holds capacitor plates
A capacitor's plates experience an attractive electrostatic force due to their opposite charges when connected to a battery, which raises questions about the forces maintaining their mechanical equilibrium. The plates are typically secured by a frame or dielectric material, preventing collapse, but concerns arise when air acts as the dielectric and weak connections are used. The energy dynamics of the system indicate that as the plates move closer, the total energy decreases, which is energetically favorable. Despite the small magnitude of the electrostatic force, the plates may still move towards each other, influenced by factors like inertia and friction. Demonstrations, such as those at the Exploratorium, illustrate the movement of charged objects under electrostatic forces.
akhil123
For any capacitor, whose 2 plates or conductors are being held by a battery to a constant potential difference of V volts, there is a force of attraction between the plates, since they are oppositely charged. What is the force that 'holds' these conductors at their respective positions i.e. what is the force that maintains mechanical equilibrium of each plate?
The capacitor plates aren't just floating in mid-air. They are usually attached to a frame or the space between them is filled with some material.
The dielectric slab will prevent the plates from collapsing onto each other...but what if the dielectric is air? And if the wires used to connect the conductors to the remaining circuit are weak copper strands? I am asking this because,when the net energy change for the (battery+capacitor) system is calculated when plates move nearer because of this attractive force, the total energy of the system decreases, and decrease of energy is always favourable for any system to achieve.
The electrostatic force is pretty small, but yes the capacitor plates will move towards each other. Depending on inertia, friction, air movement, etc, they may or not come into contact. At the Exploratorium in San Francisco we had a big box with two thread loops hanging from the top, one a bit shorter than the other so they couldn't "collide", you could charge up the threads with the same or opposite polarities of static electricity and watch them move.
Thanks a lot!
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
