Improve and Secure Your Cipher: Expert Tips and Feedback
  • Thread starter Thread starter anarkest
The discussion centers on feedback for a new mathematical cipher, with participants questioning its security and suggesting improvements. Concerns are raised about the reliance on a key, as it may be vulnerable to attacks that exploit knowledge of the algorithm and key length. The importance of not revealing entire decimals in the cipher is emphasized, as it could simplify decryption. Suggestions include using variable-length codewords to obscure word lengths and enhance security. Overall, the conversation highlights the need for careful consideration of key management and algorithm transparency in cipher design.
anarkest
Mathematics news on Phys.org
I don't think the key improves security. It should not be too difficult to look at the fractional parts and decide what numbers are possible keys (depending on how many digits are given). And depending on how many digits you give, you may also clip letters from the end of long words.
what if the division gives irrational number?
What if dividing two integers gives an irrational number?
I dare say you probably don't care what the message is anymore.
The simplest attack on this is obviously the fact that you need a key.
A lot of work might be able to be done to determine what the key is even if somebody doesn't know. For example, if I see that one of your encrypted words is .015 I know that your key must be relatively large, so starts with a letter near the end of the alphabet. I'm sure that some number theory could be used to drive home at possible keys.
There's no real reason to break up your numbers into blocks of 8 besides this cell phone thing. Usually characters are broken up into blocks so that when transmitted you don't give away what the word lengths are. You don't have such a problem here, and it could make it harder to decrypt if you use different length codewords, because then you'll be transmitting a wider range of numbers. This would mean that the intercepting party has no idea how long the codeword is which would probably be a good thingOne good thing is to not send over the whole decimal, which is how you presented it. Otherwise I could simply find what the decimal is in smallest form and then just scale it upwards until the numerator and denominator both fit the pattern necessary for a codeword. I tried that on two of the decimal numbers you had and it doesn't work because you don't get the full number
My initial thought is that the security of modern ciphers is such that knowledge of the algorithm, which is typically publicly available, does not jeopardize the security of the cipher. In your case, if I know the algorithm, a simple brute force attack on the key space should crack the cipher, since I need only to multiply each cipher text word with different keys. Now, the security of your cipher certainly improves as you make the key longer. However, now you must also make the world length longer. In the limit that the key becomes equal in length to the plain text message, you have the well known one-time pad, which is indeed provably secure (in the event that your key is truly random and used only once).
That can't possibly happen. Both numbers involved in the division are integers, so the quotient will necessarily be rational. By definition, a rational number is the quotient of two integers.
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
Thread 'Imaginary Pythagoras'
I posted this in the Lame Math thread, but it's got me thinking. Is there any validity to this? Or is it really just a mathematical trick? Naively, I see that i2 + plus 12 does equal zero2. But does this have a meaning? I know one can treat the imaginary number line as just another axis like the reals, but does that mean this does represent a triangle in the complex plane with a hypotenuse of length zero? Ibix offered a rendering of the diagram using what I assume is matrix* notation...
