- 5,774
- 174
Quick question: from which topological consideration can one derive the fact that a sphere S² does not allow for a globally flat geometry?
quasar987 said:Because it would mean that there is a diffeomorphism S^2 -->R^2
tom.stoer said:Quick question: from which topological consideration can one derive the fact that a sphere S² does not allow for a globally flat geometry?
quasar987 said:Ok, I thought globally flat meant there exists a global isometry from S^2 + some metric to R^2 + usual metric.
tom.stoer said:@lavinia: thanks for reminding me to these facts
Let me see if I understand. The Euler characteristic of S² is 2. This can be seen by using a triangulation on S² or by calculating
\chi_{S^2} = 2 - 2g_{S^2}
and using
g_{S^2} = 0
But by Gauss-Bonnet we know that
\chi_{S^2} = \frac{1}{2\pi}\int_{S^2}K
Global flatness would imply K = 0 globally which results in \chi_{S^2} = 0 which is a contradiction.
arkajad said:Well, an infinite cyllinder has a globally flat geometry, but there is no diffeomorphism from the cylinder onto R^2.
But you may check this ion Wikipedia: "Vector fields on spheres". Global flatness of S^2 would imply existence of two nowhere vanishing vector fields.
lavinia said:generally global flatness only implies the existence of one nowhere vanishing vector field.
arkajad said:S^2 is two-dimensional, connected and simply connected. You choose two orthonormal tangent vectors at one point and transport them using parallel transport to every other point. This transport is path independent (zero curvature plus topology). This way you would get two orthonormal vector fields. While by Adams' theorem even one does not exist.
lavinia said:this is wrong. There are no independent vector fields on the 2 sphere.
tom.stoer said:By inspection of 2-2g = 0 only g=1 allows for globally flat geometries.
Another related question: The Gauss-Bonnet theorem restricts the existence of globally flat geometries. What about the other way round? Suppose I have a manifold for which I can proof that the Euler characteristic vanishes. Does this automatically guarantuee that a globally flat geometry must exist? I guess not, but what are the other restrictions?
arkajad said:1) That is what I was saying, assuming hypothetically global flatness - as in the original question. Proof by contradiction. There is not even one.
2) Whether a given manifold is globally flat or not depends on the Riemannian metric. R^2 can be made globally flat and can be made non-flat even locally. Up to you.
