Transformer notation confusion?
The discussion revolves around understanding the transformer ratings for an open circuit (OC) and short circuit (SC) test, specifically for a transformer with primary ratings of 240/480V and secondary ratings of 120/240V. The confusion arises from the dual voltage specifications, which indicate that the primary consists of two coils that can be configured in series or parallel to accommodate different input voltages. Participants clarify that if the higher voltage is used, the coils should be wired in series, while for the lower voltage, they should be wired in parallel. The original poster is uncertain about how to proceed with the tests without a clear schematic of the transformer configuration. Ultimately, it is suggested that the transformer can be treated as having a primary of 480V and a secondary of 240V for the purpose of the tests.
rock.freak667
For a transformer, I need to get the ratings on the meters (wattmeter, ammeter, voltmeter) when it is put through an open circuit test and a short circuit test.
Primary 240/480
Secondary 120/240
1KVA
60Hz
Now I am not sure what is meant by 'Primary 240/480' and 'Secondary 120/240'. In most transformer problems, I would be told something like 6600/230 V transformer, meaning Primary = 6600 V and secondary = 230 V.
Anyone care to guess what it means?
In the case of http://system.netsuite.com/core/media/media.nl?id=3868&c=ACCT126831&h=9037aabf87bb8934b400&_xt=.pdf" (which I have worked with) the primary is actually two separate windings, which may be wired either in series or in parallel.
Each winding is to get the lower voltage of the two indicated primary specifications; when wired in series, the series combination would then get twice this voltage, or the higher primary specification.
Similarly, the secondary consists of two separate windings which may be combined either in series or in parallel.
If this is the case for your transformer, you should have 4 input wires and 4 output wires.
That sort of confuses me more, as then it seems as if the 240/480 side is itself like a transformer with a primary side of 240V and a secondary side of 480 V?
If that is the case, then there is no need to really consider the 240 V?
Otherwise, I am not sure how I would get the ratings for the OC and SC tests with the configuration.
No, the primary side consists of two coils with equal numbers of turns. The purpose of having two coils is that the transformer could be used with two different input voltages. Did you see the schematic at the lower left of the .pdf file I linked to before? If the input is the higher voltage, the primary coils should be wired in series; if the input is the lower voltage, they get wired in parallel.
How many wires are coming out of your transformer? If my explanation was correct, there should be 8 wires.
I understand a bit better now.
Well you see right, I don't have a picture of the transformer per se. It is sort of a lab thing I have to do and I was asked to give the ratings. The most I can get is the schematic of how the usual transformer looks during the OC and SC tests, not with the two coils in series/parallel.EDIT: So that means I don't really need to bother about the two voltages and just use the transformer as if it were specified as 480 (primary) and 240 (secondary)?
