Help! Understanding Torque on a Door
  • Thread starter Thread starter jazjackson12
    Torque
The discussion focuses on understanding the torque exerted by a doorstop when a door crashes into it compared to the torque applied to open the door. Torque is influenced by the distance from the hinges and the force applied, which varies depending on the speed of the door's movement. The relationship between torque, angular acceleration, and the duration of force application is emphasized, indicating that quicker changes in angular velocity require more torque. It concludes that the torque exerted by the doorstop is different from the torque applied to open the door due to these varying factors. Understanding these principles is essential for accurately comparing the two torque scenarios.
jazjackson12
Help! Torque
undefinedundefined Hello, please help me answer this question using definitions, principles, and reasoning: How does the torque that a doorstop exert on a door (as the door crashes into it), coming to a stop suddenly, compare to the torque you exert on a door to start it opening? Is the doorstop torque larger, doorstop torque smaller, or are our torques the same?
That depends on where you place the doorstop and on how fast you open or close the door! :-)
What forces are you applying to the door and what distance from the hinges? Those are the two things that determine torque.
It's been like half a semester since I did torque so excuse any errors :wink:
IIRC, one of the formulas dealing with torque was
M = I_c \alpha
M is basically torque, alpha is acceleration, and Ic you can just ignore. Quicker angular acceleration means more torque.
Actually, it's more a conceptual problem and than actually having to solve the equation. ShawnD gives you the equation for determining torque, except alpha is angular acceleration to be more precise.
Angular acceleration is the rate that the angular velocity is increasing or decreasing. If your torque is constant, the longer you apply it, the greater your change in angular velocity. The shorter you apply it, the less your angular velocity changes.
In this problem, the change in angular velocity is constant. The amount of time it takes to change your angular velocity is not. Therefore, the amount of torque applied must be different, as well.
