m.e.t.a.
- 111
I was taught that Huygens's principle is an accurate description of the way light propagates. Something like: "All points along a wave front can be modeled as point-sources for new waves having the same phase and frequency." This appears to be a good model to explain phenomena such as diffraction.
From my limited understanding, Huygens's principle also explains why light* travels in approximately straight lines: all possible photon paths cancel destructively except for those in a narrow central ~cylindrical beam. (Not sure about the exact "shape" of the beam. I assume a cylinder or cone as an approximation.)
The above explanation is well and good, and I understand some parts of it to a limited degree, but there is one point that I don't understand at all. If Hugens's principle explains why light travels in a straight line, does it also explain why light travels in (apparently) only the positive or negative direction along that line--but not both? My interpretation of Huygens's principle, when applied to a photon, is that the photon has equal probability to travel forwards (along its straight-line path/cylinder) as backwards. Furthermore, the photon need not travel only in the positive direction, or only in the negative, but could alternate between the two directions anywhere up to an infinite number of times between its emission and eventual absorption--if absorption ever occurred--and could hence be inferred to have traveled at any speed < c.
What is wrong with this reasoning?
* Further question: does a photon have to be coming from an extended source in order to have directionality? By "extended source" I mean something like a slit or hole; and by "having directionality" I mean that the photon propagates in a manner other than symmetrically in all directions, as an expanding sphere. For example, a photon from a laser would be "highly directional".
