Titrating Biodiesel for soap content
  • Thread starter Thread starter whatarascal
    Biodiesel Soap
To prepare a 1-liter solution of 0.01 N hydrochloric acid (HCl) from a 38% (12 N) concentrated HCl solution, dilute 0.83 mL of the concentrated acid in a 1-liter volumetric flask and fill to the mark with distilled water. If precise measurement of less than 1 mL is challenging, an alternative method is to mix 1 mL of the concentrated acid with 5 mL of water, then use 5 mL of this diluted solution to make up the final 1-liter volume. This approach allows for easier handling while achieving the desired concentration.
whatarascal
Good afternoon people
I wish to titrate biodiesel for soap content.There are video's on you tube describing how.
I have all the bits required including bromophenol blue and hydrochloric acid.
The acid is at 38% and I need a solution of .01N HCl.
Well its a long time since I was at school and even then I may not have been capable of working this out.
I require 1 litre of the .01 solution.
Would one of you bright young sparks tell me how to work this out or better still calculate it for me.
It would be great if I knew the right amount of acid to add to the distilled water.
Thanks a lot in advance
Chemistry news on Phys.org
You are talking about making up a 0.01 N solution rather than a 0.0100 N solution so you don't need to be very exact since you only want 1 significant figure for your standard. If that's what you want, dilute the 38% HCL (12 N) by adding 0.83 mL of the concentrated acid to a 1L flask and dilute to the mark. If you can't accurately measure less than 1 mL, first add 1 mL strong acid to 5 mL water and use only 5 ml of the resulting 6 mL of solution in a liter of water.
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
43K
