Does Heating a Balloon Affect its Surface Energy?
Heating the air inside a balloon at constant pressure raises the temperature, which can affect the balloon's properties. The discussion centers on whether the balloon has surface energy and its origin, with some suggesting it relates to the elastic forces of the stretched material. As the balloon expands due to heating, there is a belief that surface energy increases with surface area. However, a counterpoint is made that there is no change in surface energy despite the increase in temperature and surface area. The conversation seeks clarification from experts on the relationship between heating, surface energy, and balloon elasticity.
zorro
What will happen to the surface energy of a balloon when the air inside it is heated at a constant pressure?
I don't understand how will a balloon have surface energy. What is its origin? Is it due to the elastic forces of the stretched balloon?
If yes then the surface energy increases as its surface area increases on heating.
Any ideas appreciated.
Yes, it has to be that way. Imagine the surface as a net. Each molecule acts as a micro-spring (a connection of the net).
Right
You are wrong. There is no change is surface energy (as per the answer). This was the doubt that made me post this question. Experts please reply.
