Should I Replace Only the Boiler or the Entire Heating System?
  • Thread starter Thread starter epipeinfo
    Boiler System
Replacing a back boiler with a combi boiler raises questions about whether to also replace the existing radiators and pipework. A thorough flush of the current system may suffice if there are no significant changes in pressure, flow rate, or temperature. However, if the new boiler alters these parameters, upgrading the radiators and pipes could be necessary. An inspection of the current system's reliability is also recommended. Ultimately, the decision should consider the compatibility of the existing components with the new boiler's requirements.
epipeinfo
Hi,
I'm planning to replace a back boiler (which is at least 15 years old) with a combi boiler. Assuming that the rest of the system is the same age, is it sufficient to flush the existing radiators and pipes, or is it better to replace the radiators and pipework as well?
Duraflow | Leaky Pipes
Welcome to PF, Epipeinfo.
Your terms confuse me, as to what "back" and "combi" mean, but that's irrelevant to the rest of the question. Someone more knowledgeable will appear shortly. Meanwhile, my thought is that if there won't be significant changes in pressure, flow rate, or temperature then a simple flush and an inspection to ensure reliability should be enough. If there will be changes, then the piping and rads might need to be upgraded to meet the new requirements. This is far beyond my ability to advise upon.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
