Is their a probabilistic to deterministic calculator web abb?
  • Thread starter Thread starter Ryang
    Calculator Web
A user is developing a mathematical model focused on mutation rates in a hypothetical organism and seeks a genuine random number generator to convert probabilities into certainties for graphing mutations. They require a generator capable of producing numbers between 1 and 3 billion, expressing dissatisfaction with existing options like Random.org, which cannot handle numbers above 100 million. The discussion highlights the difference between genuine and pseudo-random number generators, with some participants suggesting that the user's issues may stem from improper use of a pseudo-random generator. There are recommendations for programming solutions in C or Matlab, but the user prefers a straightforward application due to limited programming knowledge. The conversation emphasizes the need for a reliable tool to facilitate their modeling work.
Ryang
Hello. I'm currently making (or attempting to make...) a mathematical model based around mutation in a hypothetical organism (that is, one in which all the mutation rates and genome sizes are known).
I am currently graphing a particular feature of this model, involving mutation rates, but I don't have a 3x108 sided dice to change probabilities into certainties. In order to graph the number of mutations I need to know for certain if a mutation HAS or HASN'T occurred, not its chances of actually happening. Is there any free application which will "throw the dice" for me??
Thanks
Mathematics news on Phys.org
So... you want a random number generator? If you're writing a program in C or Matlab or whatever, they should have a built in random number generator, or a library you can download by googling random number generator. What kind of random number generator do you want? 3x10^8 outcomes with equal probability?
This model is equations and spreadsheets only, and I no little about programming. Anyway, I need a genuine random number generator, not an periodic psuedorandom code-based number generator (One I was using seemed to repeatedly give me numbers over ^6, never below).
I found one genuine random number generator, Random.org, which is handy, but it can't handle numbers over ^8, which is unfortunate as I need one that can handle ^9 :(.
I just need a program that will randomly generate one number between 1 and 3,000,000,000.
I doubt whether being pseudorandom causes this. Did you check thousands of values for the few which would be less than 1000000?
I don't see why a pseudo-random number generator would be a problem. I've never heard of anyone having to use a genuine random number generator. If your pseudo RNG isn't giving you what you expect, you might be using it wrong or using one with a range of values not suitable for your purposes.
[strike]As for the RNG you were using, you can choose to get integers between 0 and ~10^8, so you could always just multiply every result you get by 10. This increases the mean and standard deviation, but if the numbers are close to uniformly distributed it doesn't matter.[/strike] Scratch that, that only works for real numbers. For integers you'd lose 1 to 9.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
