Solving ODE with Data Points: Finding Equation and Integrating Method
  • Thread starter Thread starter RagincajunLA
    Ode
To solve the ordinary differential equation h' = ah^b - ch^d using given data points, it is essential to estimate the constants a, b, c, and d. By applying methods for deriving a function's derivative from discrete data, one can treat the data as a high-order polynomial approximation. This leads to a non-linear fitting problem where the estimated derivatives h'i can be used to find the constants. Various algorithms and software are available to facilitate this fitting process. Alternatively, Wolfram Alpha can be utilized for integration, although it may involve complex functions like the hypergeometric function.
RagincajunLA
hey guys, i was given some data points and i had to find an equation to fit the model. now my differential equation is h'= ah^b - ch^d with b < 0. I can't find any method for integrating because i don't know the constants in the equation. but i have the data points so that must help somehow. i also know the maximum and minimum of the data points. someone please help me figure out how to integrate this.
If your task is to find constants a, b, c, and d, such that h(t) satisfying dh/dt = ah^b - ch^d fits the given points (hi, ti), then finding general solution to h(t) might be a backwards way of doing things.
There exist methods for finding a derivative of a function at a point given some discrete data set. These are approximate, but they essentially assume that your data is a high-order polynomial, and the solution to your ODE can be at least approximated with one.
So, use your set of hi and ti to find estimates for h'i. Now you have a standard non-linear fitting problem f(hi,a,b,c,d) = h'i. There are a number of ready algorithms and programs that can take care of both steps.
Otherwise if you are daring you can try wolframalpha.com [integrate 1/(a*x^b - c*x^d)]. Spoiler: you'll have to like the hypergeometric function
So I know that electrons are fundamental, there's no 'material' that makes them up, it's like talking about a colour itself rather than a car or a flower. Now protons and neutrons and quarks and whatever other stuff is there fundamentally, I want someone to kind of teach me these, I have a lot of questions that books might not give the answer in the way I understand. Thanks
