How Many Milligrams of Fluoride Are in 8 Cups of Water?
To determine the fluoride content in 8 cups of water, first convert the volume of water to cubic centimeters, knowing that 1 cup equals approximately 237 cm³. With 8 cups, the total volume is about 1896 cm³. Given the fluoride concentration of 1.00 part per million (ppm), this means there is 1 mg of fluoride per 1,000,000 mg of water. Therefore, by calculating the mass of water and applying the ppm ratio, you can find the total fluoride content consumed daily from 8 cups of water. Understanding the conversion and application of ppm is essential for accurate calculations.
leroyjenkens
Nutrition experts recommend that you drink at least 8 cups of water daily. If your local water supply contains 1.00 part fluoride (by mass) per million parts water, how many milligrams of fluoride would you consume daily in your 8 cups of water? (use 1.00 g cm^-3 as the density of water)
I just don't know how to set this up. I tried putting 1.00 part fluoride over 1 million parts water, but that just made a mess. Fluoride is in parts and I have to convert that to milligrams. I'm lost on how to do that.
Thanks.
1 ppm of F by mass just means that for any mass of water, the mass of fluoride present in it will be one millionth that.
So all you have to do is calculate the mass of water present, and then divide that by 106 to get the mass of fluoride in that water.
EDIT: Since the density of water is given in cgs units, you'll have to convert the given volume of water to cgs units.
