X and y lin independent in Rn A=xy^T+yx^T
  • Thread starter Thread starter Keesjan
    Independent
Keesjan
Well as the title describes, x and y linear independent in R^n S is a subspace in Rn spanned by x,y i.e S= span(x,y)
define the matrix A as A=xy^T+yx^T
This is actually a 3 part question
1 show that A is symmetrical
2 show that N(A)=S(Perpendicular)
3 show that the rank of A is 2
I think i got the first one
A^T= (xy^T+yx^T)^T = (y^T)^Tx^T+(x^T)^Ty^T= yx^T+xy^T=A QED
Dimension is abbreviated as Dim
Rowspace abbreviated as R(*)
Column space will be abbreviated as C(*)
and perpendicular as perp
Now the second one i think has something to do with the N(A)=C(A^T)^perp.
And because A^T=A now N(A)=C(A)^perp
Span of the DimC(A) is span of S because x,y are linear independent?
And if DimC(A)=Span(x,y) then DimC(A)=S
So filling it all in N(A)=S^perp QED??
is this correct?
Last question
Since x and y are linear independent they form the basis of A. So DimC(A)=2
And since the DimC(A)=DimR(A) and the rank=DimR so Rank(A)=2
Any feed back would be nice.
Peace
To show that N(A)= S(perpendicular) You need to show that A(u)= 0 (so u in in N(A), the null space of A) if and only if <u, v>= 0 for all v in S.
What do you mean with <u,v>=0 for all v in S
Maby i don't under stand the notation but could you explain a little more?
Thanks
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
