Can weight reduction be optimized in automobile superstructures?
  • Thread starter Thread starter ruzfactor
    Automobile
The discussion centers on optimizing weight reduction in automobile superstructures, specifically regarding the phrase "properties optimized for weight reduction." Key factors include using materials with low density and minimizing component volume to achieve the lightest possible design. Manufacturing processes also play a crucial role in determining the feasibility of lightweight components. The conversation emphasizes that cost is not a concern when prioritizing weight reduction. For further information on service conditions of auto bodies, relevant data sources should be consulted.
ruzfactor
someone please explain the phrase "properties optimised for weight reduction" in case of auto body and spaceframes.
Also please refer some links to some data on service conditions of auto body.
Thanks in advance.
Assuming we only want the lightest components and do not care about cost. ..I believe it comes down to density and volume. Making components with the smallest volumes possible out of materials with lightest densities are the major properties. Keep in mind components are also dependant on manufacturing processes and other factors
Thread 'Turbocharging carbureted petrol 2 stroke engines'
Hi everyone, online I ve seen some images about 2 stroke carbureted turbo (motorcycle derivation engine). Now.. In the past in this forum some members spoke about turbocharging 2 stroke but not in sufficient detail. The intake and the exhaust are open at the same time and there are no valves like a 4 stroke. But if you search online you can find carbureted 2stroke turbo sled or the Am6 turbo. The question is: Is really possible turbocharge a 2 stroke carburated(NOT EFI)petrol engine and...
I need some assistance with calculating hp requirements for moving a load. - The 4000lb load is resting on ball bearing rails so friction is effectively zero and will be covered by my added power contingencies. Load: 4000lbs Distance to travel: 10 meters. Time to Travel: 7.5 seconds Need to accelerate the load from a stop to a nominal speed then decelerate coming to a stop. My power delivery method will be a gearmotor driving a gear rack. - I suspect the pinion gear to be about 3-4in in...
