Isn't this weird? (convergence of a sequence)
  • Thread starter Thread starter quasar987
    Sequence Weird
The discussion revolves around the convergence of the sequence \(\left\{\frac{n^2}{n^2+4}\right\}\) towards 1, using the \(\epsilon-N\) definition of convergence. Participants explore the implications of their reasoning and the validity of their approaches in proving convergence.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants examine the conditions under which the sequence converges to 1, questioning whether proving convergence to 1 is equivalent to proving convergence to any positive real number. They discuss the validity of inequalities used in their reasoning and the implications of specific values of \(n\).
The discussion is active, with participants providing feedback on each other's reasoning. Some suggest reconsidering the approach due to potential flaws in the inequalities presented, while others propose alternative methods to demonstrate convergence. There is no explicit consensus on the correctness of the approaches, but productive dialogue is ongoing.
Participants note that certain values of \(n\) may lead to failures in the inequalities being used, and there is an acknowledgment of the complexity in proving convergence under the given definitions.
quasar987
In order to prove, using the [itex]\epsilon-N[/itex] definition, that the sequence
[tex]\left\{\frac{n^2}{n^2+4}\right\} = \left\{\frac{1}{1+\frac{4}{n^2}}\right\}[/tex]
converges towards 1, I did the following: The sequence converges towards 1 if
[tex]\forall \epsilon>0, \exists N\in\mathbb{R} \ \mbox{such that} \ \forall n\in\mathbb{N}, n>N \Longrightarrow \left|\frac{1}{1+\frac{4}{n^2}}-1\right|<\epsilon[/tex]
We have that
[tex]\left|\frac{1}{1+\frac{4}{n^2}}-1\right|<\left|\frac{1}{1+\frac{4}{n^2}}\right|[/tex]
so if we can find the N for the creature on the right side of the inequality, it will also be true for the one on the left side. And then we solve and I spare you the following steps because my question is that if my line of reasoning is correct so far, then proving that there exist an N for the right member proves that there exists an N for
[tex]\left|\frac{1}{1+\frac{4}{n^2}}-a\right|[/tex]
where a in any positive real. So it doesn't REALLY show that the limit is 1 because should I try to prove that the limit is "a, any positive real", I would arrive to the same answer! All it shows is that the sequence converges. Right?
quasar987 said:
We have that
Actually, we don't. n=1 fails. For large enough n (3 or more), this inequality will be true.
However, you won't be able to bound the right hand thing above by an arbitrary [tex]\epsilon>0[/tex]. Forget an arbitrary one, take [tex]\epsilon =1/5[/tex] and you won't be able to do it, since it's false for all n (any epsilon less than 1 will also fail).This thing starts at 1/5 and approaches 1, it's not getting arbitrarily small.
quasar987 said:
We have that
But can you ? Notice that this creature doesn't get smaller than 1/5...ever.
PS : shmoe's post wasn't up when I started...so ignore this.
Ok, thanks for pointing that out. I start again.
[tex]\forall \epsilon>0, \exists N\in\mathbb{R} \ \mbox{such that} \ \forall n\in\mathbb{N}, n>N \Longrightarrow \left|\frac{n^2}{n^2+4}-1\right|<\epsilon[/tex]
We have that (with some luck),
[tex]\left|\frac{n^2}{n^2+4}-1\right|<\left|n^2-1\right|<\left|n^2\right|=n^2[/tex]
which is an easily tamed creature that produces an N that is true for all N such that
[tex]N\geq \frac{1}{\sqrt{\epsilon}}[/tex]
So my argument remains, that is to say, isn't it weird that since showing that this converges to 1 is the same as showing that it converges to any a, positive real. So it doesn't REALLY show that the limit is 1 because should I try to prove that the limit is "a, any positive real", I would arrive to the same answer! All it shows is that the sequence converges. Right?
[tex]\left|\frac{n^2}{n^2+4}-1\right|<\left|n^2-1\right|<\left|n^2\right|[/tex]
It's going to take a lot more than "some" luck !
Try n=1 and see what happens.
And I suggest you don't spend a whole lot of time trying more of these ...any such attempt must fail.
Bad luck!
I found another way of doing it (thanks to Fredrik's trick) that DOESN'T "cause" the paradox I was invoking, so it should be right this time! (notice I used the word "should" :wink:). Here we go again.
We have that, *crossing my fingers*
[tex]\left|\frac{n^2}{n^2+4}-1\right|=\left|\frac{n^2+4-4}{n^2+4}-1\right|=\left|1-\frac{4}{n^2+4}-1\right|=\left|-\frac{4}{n^2+4}\right|=\frac{4}{n^2+4}<\frac{4}{n^2}<\epsilon[/tex]
[tex]\Leftrightarrow n^2>\frac{4}{\epsilon}\Leftrightarrow n>\sqrt{\frac{4}{\epsilon}}[/tex]
we discarded the option that n was greater than minus the square root because it is trivial by n being a positive interger. So any N satisfying
[tex]N\geq \frac{2}{\sqrt{\epsilon}}[/tex]
is fine.
  • · Replies 21 ·
