Question About Aero Bike Idea - Mike Flanagan UK
  • Thread starter Thread starter Flantoons
    Bike
The Aero Bike concept involves storing energy in the bike's frame by using arm pumps on the handlebars to create air pressure, alongside regenerative braking. Concerns were raised about the practicality of this design, particularly regarding the difficulty of riding while managing the added complexity and potential discomfort from the pumping mechanism. Critics highlighted that compressed air has a low power-to-weight ratio, making it inefficient for propulsion and energy storage in a bicycle context. The design may require a stronger frame to handle the pressure, which could negate any benefits from the energy storage. Overall, the consensus suggests that the system could be more tiring and awkward compared to traditional biking methods.
Flantoons
Please, may I ask for a comment on my idea for the Aero Bike?
I want to store energy in the frame of the bike, by pumping with your arms on the
handlebars to create air pressure, (at the same time as you do your normal
pedaling). Also perhaps regenerative braking can store energy too.
My drawing here explains the idea.
flantoons.co.uk/aero-%20bike.jpg
Many thanks,
Mike Flanagan UK
Can you actually ride that? If you're leaning forward with weight on the handlebars, how do you pull them up? Even then it would be horrible hard work, and bad for your back. Same with the cylinder on the front fork. That's why some mountain bikes can have the shock absorbers locked up, so you aren't wasting energy doing all that pumping.
I like the idea of utilizing that empty space inside the frame. But I doubt you could store any useful amount of energy like that. If you put any significant pressure in it, the frame would have to be made stronger to take the ordinary bike loads added to the pressure load, and with enough safety factor to prevent it exploding or becoming like a rocket when it cracks.
Compressed air is basically useless for propulsion of normal vehicles because it has a very low power to weight ratio. You need a lot of heavy pressure vessel to hold much energy.
Goes against all convention of bike design. You don't what bits to move that don't have to as that wastes energy from going forward. Let's take a look at the energy path for a rigid bike, we know the more steps we add the less efficient a system is.
With a rigid bike.
You -> Pedals -> Motion.
With your system
You -> Compressed air -> Pedals -> Motion.
The vast majority of the time you are temporarily storing energy only to be used a split second later. It would be far less tiring to just pedal a rigid bike. As you are the only input, your system will be far more tiring and awkward to ride.
As unrest said, you aren't going to store that much energy even if you can store it at all. Especially the way yuo've drawn it. Either you are comrpessing air with the pedals also (doing work against yourself), or you are just venting the pressurised air into the atmosphere as you have no mechanism to stop the air from rushing out the piston chamber.
Then you need to ask the question, if you sort out a mechanism to store the pressure and realease it on que. Is it really worth the extra weight and complexity?
I think it might also be difficult to release the energy at the proper time. In your drawing, if the compressed air is pushing the piston towards your pedals than it would assist in your pedaling motion. However, if the the gear were rotated 180 degrees and the compressed air were pushing the piston towards the pedals then you would actually be opposing your pedal motion. So you would have to make sure that the power stroke is in phase with your pedaling.
How did you find PF?: Via Google search Hi, I have a vessel I 3D printed to investigate single bubble rise. The vessel has a 4 mm gap separated by acrylic panels. This is essentially my viewing chamber where I can record the bubble motion. The vessel is open to atmosphere. The bubble generation mechanism is composed of a syringe pump and glass capillary tube (Internal Diameter of 0.45 mm). I connect a 1/4” air line hose from the syringe to the capillary The bubble is formed at the tip...
Thread 'Physics of Stretch: What pressure does a band apply on a cylinder?'
Scenario 1 (figure 1) A continuous loop of elastic material is stretched around two metal bars. The top bar is attached to a load cell that reads force. The lower bar can be moved downwards to stretch the elastic material. The lower bar is moved downwards until the two bars are 1190mm apart, stretching the elastic material. The bars are 5mm thick, so the total internal loop length is 1200mm (1190mm + 5mm + 5mm). At this level of stretch, the load cell reads 45N tensile force. Key numbers...
I'd like to create a thread with links to 3-D Printer resources, including printers and software package suggestions. My motivations are selfish, as I have a 3-D printed project that I'm working on, and I'd like to buy a simple printer and use low cost software to make the first prototype. There are some previous threads about 3-D printing like this: https://www.physicsforums.com/threads/are-3d-printers-easy-to-use-yet.917489/ but none that address the overall topic (unless I've missed...
