Mass, Rest Frames & Neutrinos: Explained
  • Thread starter Thread starter Lapidus
    Neutrino Rest
Lapidus
So every particle with some mass, even if the mass is very, very close to zero has a rest frame. A neutrino, say, could sit right next to me. But a photon, a massless particle, of course, can't, it has to zip by with light velocity.
But when I would reduce the mass of a particle slowly towards zero, how is this sudden and abrupt change of behaviour, that there is no rest frame anymore for zero mass, explained?
(Which equation shows that best?)
Or does it require more and more energy to keep a ever lighter particle at rest? But then all frames a equal by Lorentz transformation, and there is always a rest frame for a particle which does not move with c...
confused!
thanks
Hi Lapidus! :wink:
Lapidus said:
… But when I would reduce the mass of a particle slowly towards zero, how …
But we can't reduce (or increase) the mass of a particle …
the mass (ie rest-mass) of each particle is fixed. :smile:
in addition to tiny tim's comments, don't forget that light has energy. For any fixed E the v goes smoothly to c as m goes to 0.
Right, v goes smoothly to c as m goes to 0, so that the denominator and numerator of the expression for the relativistic energy become both zero.
But isn't it that for very small masses quantum physics has to come into play?
Does not quantum physics, with its Broglie wavelength or even Comton wavelength for particles, blur the concept of localization and thus the concept of a rest frame?
Does quantum physics (relativistic quantum physics) give a more smooth transition to the massless case with no rest frame?
No, the relativistic energy is well-defined even for a massless particle. You do not get division by 0.
For quantum physics I think the only answer is tiny tim's answer that mass of quantum particles does not vary so your situation is simply not possible quantum mechanically. For non-quantum relativistic physics the transition is smooth already, as I mentioned above.
To answer your original question, you can imagine a series of particles with smaller and smaller mass. As the mass becomes small, it becomes more and more difficult to keep the particle at rest. The slightest bit of energy will cause it to go scooting off at near light speed.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
