What are some factors that affect the drying time of table utensils?
  • Thread starter Thread starter jangheej
    Drying Experiment
Drying time for table utensils varies based on several factors, including material type, temperature after rinsing, and thermal mass. Materials like glass, plastic, wood, ceramic, and stainless steel exhibit different drying rates. The geometry of the utensils also plays a significant role, as it affects convective heat transfer and water evaporation. Larger surface areas and fewer obstructions enhance drying efficiency through increased convection. Understanding these parameters is crucial for a comprehensive analysis of drying times.
jangheej
hi =)
i'm doing an experiment on 2011 iypt problem Air Drying.
-> "table utensils, after being washed, dry differently. Investigate how the drying time depends on relevant parameters."
I've just begun on the experiment and have difficulty figuring out where to start!
I'm thinking about measuring the drying time depending on different material(glass, plastic, acryl, wood, ceramic, stainless steel).
What else could be a "relevant parameter"?
Can you suggest some ideas??
How about the temperature of the utensils after they are rinsed, and their thermal mass? A heavy ceramic plate that emerges from the rinse very hot should dry quickly.
You should definitely evaluate the geometries of the utensils, since the drying will occur by convective and natural diffusion as the small pools of water expel their vapor pressures. More convection means higher diffusivity, which is a direct result of geometrical obstructions and/or greater surface areas.
Thread 'I need a concave mirror with a focal length length of 150 feet'
I need to cut down a 3 year old dead tree from top down so tree causes no damage with small pieces falling. I need a mirror with a focal length of 150 ft. 12" diameter to 36" diameter will work good but I can't think of any easy way to build it. Nothing like this for sale on Ebay. I have a 30" Fresnel lens that I use to burn stumps it works great. Tree service wants $2000.
Hi all, i have some questions about the tesla turbine: is a tesla turbine more efficient than a steam engine or a stirling engine ? about the discs of the tesla turbine warping because of the high speed rotations; does running the engine on a lower speed solve that or will the discs warp anyway after time ? what is the difference in efficiency between the tesla turbine running at high speed and running it at a lower speed ( as fast as possible but low enough to not warp de discs) and: i...
