Find the constant of vain (wien)
  • Thread starter Thread starter stunner5000pt
    Constant
The discussion revolves around finding the Wien constant from the equation for spectral radiancy, R(λ,T), and understanding its relationship with blackbody radiation. The original poster expresses uncertainty about manipulating the equation and how to incorporate the Boltzmann constant.
  • Participants discuss taking the derivative of R with respect to λ to find the maximum wavelength, λmax, and relate it to the Wien constant. There are questions about the necessity of expanding the exponential function and how to handle the constants involved.
Some participants have provided guidance on the steps to take, including differentiating the spectral radiancy equation and solving for λmax. There is acknowledgment that the problem may require numerical methods, but no consensus has been reached on the best approach.
The original poster is working under the constraints of homework rules, seeking assistance without direct solutions. There is also a mention of a related question about Einstein's theory for specific heat, indicating a broader context of inquiry.
stunner5000pt
Find a wien constant A from the equation [tex]R(\lambda,T) = \frac{2\pi h c^2}{\lambda^3} \frac{1}{e^\frac{hv}{kT} - 1}[/tex] Show that the Wien constant w = Lambda T = hc / 4.965k
Also i know that w = 2898 micro metres Kelvin
I'm not sure what to do here... Do i fiddle with the equation for hte spectral radiancy?? Do i expand the tern for the exp function?
But how would you manage to get the Boltzmann constant in the denominator without expanding the exp function?
Please do help with this!
Part 2 of this question is
Substitute numerical values for the constants and evalute. Compare the result with the Equation of w = 2898 [tex]\mu m K[/tex]
Now i need to solve the first part to get this second part, i would really really appreciate your help on this matter!
Thank you in advance for this!
The Wien constant is defined as the product of the temperature and the wavelength for which the blackbody radiation is a maximum:
[tex]w = \lambda_{max} T[/tex]
so what you need to do is take the derivative of R with respect to [itex]\lambda[/tex], set it equal to 0 and solve for [itex]\lambda_{max}[/itex]. Remember that [itex]\nu[/itex] depends on [itex]\lambda[/itex]. Once you find that value just multiply it by the temperature and you have Wien's constant!<br /> <br /> It's actually easier than it looks at the outset! (It might be easier to work with [itex]\nu[/itex] and switch back to wavelength at the end.)[/itex]
[itex] <br /> Wow i would never think it was that easy! But thank you very much!<br /> <br /> Could you also help me with another one ?? Please?<br /> This one has to do with Einstein's heory for specific heat<br /> <a href="https://www.physicsforums.com/showthread.php?t=49792" class="link link--internal">https://www.physicsforums.com/showthread.php?t=49792</a>[/itex]
w corresponds to the value of [tex]\lambda[/tex] for which R is a maximum. This maximum occurs at [tex]\lambda = w/T[/tex].
To find the maximum you just put
[tex]\frac{\partial R}{\partial \lambda} = 0[/tex]
and solve.
The problem is that you can only solve this numerically, since you get a transcendental equation. Good luck.
James,
Yes, but that's not a serious problem with modern calculators!
  • · Replies 26 ·
10K
