Electromagnetic Induction: Solenoid & Magnet
  • Thread starter Thread starter Kyoma
    Magnet Solenoid
Electromagnetic induction occurs when a magnet moves through a solenoid, generating an induced current. A force, attributed to the induced magnetic field, opposes the magnet's motion, as described by Lenz's law. This feedback mechanism involves a changing magnetic field inducing a current, which then creates a magnetic field that resists the change. For effective energy conversion, a coil must be positioned between two magnets, allowing it to rotate within the magnetic field. This setup enables the transformation of mechanical energy into electrical energy and vice versa, illustrating fundamental principles of electromagnetism.
Kyoma
I have just learned electromagnetic induction and it states that if you move a magnet through a solenoid, you would get an induced current.
Say, if you have a copper solenoid, and if you want to move a magnet through it, there will be something (maybe, a force) that would prevent the magnet from entering into the solenoid. Similarly, if you want to withdraw the magnet out of the solenoid, that 'something' would try to make the magnet stay in the solenoid.
According to Lenz's law, the mechanical energy to overcome that 'something' would be converted to electrical energy (the induced current).
So, what is that something?
It's a magnetic field. There's a sort of 'feedback' going on. The changing magnetic field induces a current (Faraday's law), and this current in turn induces a magnetic field opposing the change by Ampere's law. It is this induced magnetic field that opposes the motion of the magnet.
Yes it will, it's called generator. It will give out electrical energy if you will use mechanical energy by rotating the coil, and will rotate by giving electrical energy, which is electrical motor. But it has to be done correctly to work so:
You must have coil in between of two magnets, so that it is in centre of the magnetic field.
There's really not much to tell about it, it just how universe is.
So if you will rotate said coil in magnetic field,(by not touching magnets)the work is done and it will give out energy equal to given energy, that is, will give out electrical energy if you apply mechanical. And works vice-versa for giving out mechanical energy if you apply electrical energy to wires.
hope that made things clear to you.
This is from Griffiths' Electrodynamics, 3rd edition, page 352. I am trying to calculate the divergence of the Maxwell stress tensor. The tensor is given as ##T_{ij} =\epsilon_0 (E_iE_j-\frac 1 2 \delta_{ij} E^2)+\frac 1 {\mu_0}(B_iB_j-\frac 1 2 \delta_{ij} B^2)##. To make things easier, I just want to focus on the part with the electrical field, i.e. I want to find the divergence of ##E_{ij}=E_iE_j-\frac 1 2 \delta_{ij}E^2##. In matrix form, this tensor should look like this...
Thread 'Applying the Gauss (1835) formula for force between 2 parallel DC currents'
Please can anyone either:- (1) point me to a derivation of the perpendicular force (Fy) between two very long parallel wires carrying steady currents utilising the formula of Gauss for the force F along the line r between 2 charges? Or alternatively (2) point out where I have gone wrong in my method? I am having problems with calculating the direction and magnitude of the force as expected from modern (Biot-Savart-Maxwell-Lorentz) formula. Here is my method and results so far:- This...
