Implementing equation 4.19 with integration in MATLAB
  • Thread starter dorikin
    Matlab
6 replies · 3K views · last reply
dorikin
Hello everyone!
I'm trying to write out an equation in MATLAB from a book so that I can make a graph. I am stuck on how to write the intergration part of the equation.
I have uploaded a picture of the page here: http://www.flickr.com/photos/61865210@N07/5736930748/
I am trying to write equation 4.19
The code I have written so far is below. Do I have to use ode45 or quadl? I've looked in the help file but I don't understand >.<
If you have any ideas please post them, I've been trying to do this for the last day! >.<
Thank you!
ken
It will probably be more clear in the link
clear all
clc
[x,y] = meshgrid(-1:.5:1);
L=0.5;
constant=-1/(4*pi);
ln1=log(x.^2+(y-l)^2); %problem
soln= quadl(ln1,-L,L); %problem
potential=constant*soln;
mesh(x,y,potential)
Hello!
I think I have a solution.
I will post it up once I have checked it1
Thanks
ken
Thanks for letting me know, I thought it looked a bit weird *red cheeks*
Here is the solution:
"I would start by simplifying the problem a bit.
Step 1 - for a fixed x1,x2, how could I calculate the integral?
For this, you can actually use the quad function (you don't need ode45). Let's assume x1 = 7 and x2 = 3. I could create a function that would return the value of the integrand for any particular L
integrand = @(L) log(7.^2+(3-L).^2);
integrand(14)
I can then use this function to do the integral numerically
quad(integrand,-5,5)
So, we've solve step 1! :)
Step 2 - Repeat process for a bunch of x1,x2 combos
Well, this is fairly straightforward now that we solved step 1. We just use a loop.
lambda = 1;
x1 = 1:0.1:2;
x2 = 1:0.1:2;
[X1,X2] = meshgrid(x1,x2);
phi = zeros(size(X1));
for i = 1:numel(X1)
fixedx1x2 = @(L) log(X1(i).^2+(X2(i)-L +eps).^2);
phi(i) = (lambda / 4*pi) * quad(fixedx1x2,-5,5);
end
surf(X1,X2,phi)
Note that here we are using meshgrid to calculate a range of x1,x2 values over a grid, and then for each x1 and x2 we are repeating the quad call
Hope this helps!"
Thanks to anyone who tried to help me out!
ken
Mark44 said:
Minor point, but there is no such word as "intergrate."
The one you want is integrate.
There is if you have a Boston accent! My Caculus I teacher talked about "delters" and "alphers".
If you want to integrate symbolically, you can use the int() function on a sym object.
After you have done symbolic integration, you can't sub in numbers can you?
I've tired it and it doesn't seem to work but I want to double check.
thanks ken
