I am a bit confused at orthonormal tetrad in General Relativity
Junjie
I am a bit confused at "orthonormal tetrad" in General Relativity...
I think orthonormal tetrad should be a set of vectors like
e0= (1,0,0,0)
e1= (0,1,0,0)
e2= (0,0,1,0)
e3= (0,0,0,1)
However, in my book, it is written as
e0= (-1,0,0,0)
e1= (0,1,0,0)
e2= (0,0,1,0)
e3= (0,0,0,1)
I am not sure which one is right, and why it is right. My roomate think both are right, which makes me even more confused.
Your second tetrad is obtained from your first by reflecting e0. Both are correct. You could say that one set is right-handed and the other set is left-handed (if you had four-dimensional hands)
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
