Why Does My Noise Cancelling Mic Only Work When I Pinch the Wires?
  • Thread starter Thread starter wwiaftm
    Electrical
The issue involves a bike-to-bike radio microphone that only functions when the wires are pinched together, suggesting a potential connection problem. Despite attempts to solder a noise-canceling mic and various fixes, the mic fails to work unless pressure is applied. The user has explored multiple solutions, including shielding and using resistors, but none have resolved the issue. Suggestions include checking the quality of the 3.5mm plugs, as poor contacts are common with certain designs. The situation remains unresolved, indicating a deeper wiring or connection issue that needs addressing.
wwiaftm
to start off let me state the problem... I have a bike to bike radio that has a microphone and speakers. At speed of over 20mph it is very poor quality. I have cut the wires and tried to solder in a noise canceling mic. the mic does not pic up anything but If i pinch the wires
------finger------
(wire - one inch of space - wire)
------finger------
the mic works perfectly! if i connect the wires together it does not work.
one wire is insulated one is not and rides beside the insulated one.
things i have tried...
pinching to connect the wires with my bodies resistance works
covering both wires in flux works until the flux dries
sheilding the wires separately or togther does not work
i was told to try a resistor of .3 - .5 ohm this did not work
multiple mics give the same result
wiring in the old mic works fine still
any help would be helpful because i am stumped!
Is it possible that when you squeeze these wires, you are putting pressure on a poor joint nearby?
Some 3 MM plugs are notorious for this. They can be made by pressing two pieces of metal together and these sometimes make a poor contact.
You can get better plugs if this is the case. Look for the ones that have the center pin coming through to the area where it gets soldered, not the ones that have this pin joined to another piece of metal.
I did try clamps in many places last night. Across the wires, and each wire individually, neither of these seemed to work. The plugs are original and the wire is cut in the center with plenty to work from. It does not seem to be loose or bad connection problem as I have tried soldering and clamping in different places many times. Thank you very much for the thought but it still won't work.
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
33K
13K
