Why every gas would exert zero pressure at -273.15 degree celsius
The discussion centers on the behavior of gases at -273.15 degrees Celsius, where pressure theoretically reaches zero. This point, known as absolute zero, is not a coincidence but a result of the absolute temperature scale's definition. The ideal gas law is assumed to hold true until this temperature, although real gases may exhibit phase transitions before reaching absolute zero. The Celsius scale is based on the triple point of water, correlating to 273.15 Kelvin. Understanding this relationship clarifies why all gases would exert zero pressure at this temperature.
saurabhjain
I was reading about the experiment of constant volume gas thermometer today. When we extrapolate the presuure -temperature lines, the lines would meet at point -273.15 degree celsius, which is zero presure. I was wondering whether it is a matter of coincidence or some science behind it. The lines could have intercepted at some non-zero pressure. Please help me understanding this.
That extrapolation is based on the assumption that the ideal gas scenario works all the way to that value. We know that this isn't true, because at some point, there will be a discontinuity in the form of a phase transition (try extrapolating the behavior of steam across 100 C).
Zz.
But, still, it is no coincidence. The absolute temperature scale is defined so that intersection occurs at 0 K (absolute zero). The celcius scale is defined by the triple point of water, I believe, and that gives 0 Celcius at 273.15 Kelvin. Thus, you measure absolute zero at -273.15 C.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
