Is FTL Communication Possible Through Quantum Entanglement?
The discussion centers on the possibility of faster-than-light (FTL) communication through quantum entanglement, exploring theoretical implications, experimental constraints, and the role of noise in quantum experiments. Participants examine concepts related to Bell's inequalities, coincidence counters, and the delayed choice quantum eraser (DCQE) within the context of communication and information transfer.
  • Some participants argue that the use of coincidence counters in quantum experiments prevents FTL communication, as information cannot be decoded until both past and future events are correlated.
  • Others propose that if noise were minimized, FTL communication might be possible, questioning whether noise is a fundamental issue or simply a practical limitation.
  • One participant suggests that electromagnetic radiation noise does not need to be completely absent for FTL communication to be considered, but rather that it complicates the decoding of information.
  • Concerns are raised about the nature of information transmitted through entanglement, with some asserting that it is inherently random and thus not useful for communication.
  • Another viewpoint emphasizes that while DCQE experiments might suggest a method for purposeful information transfer, the need for classical communication to confirm results undermines the potential for FTL communication.
  • Participants discuss the analogy of quantum-linked dice to illustrate the limitations of using entangled particles for meaningful communication.
Participants express multiple competing views regarding the feasibility of FTL communication through quantum entanglement. There is no consensus on whether noise is a fundamental barrier or a practical limitation, and the discussion remains unresolved regarding the implications of DCQE experiments for communication.
Limitations include the dependence on definitions of information and randomness, as well as unresolved questions about the role of noise in quantum experiments. The discussion also highlights the need for classical communication to interpret results from entangled particles.
San K
Every experiment to date that has been used to calculate Bell's inequalities, performs a quantum eraser, or conduct any experiment utilizing quantum entanglement as an information channel has only been possible through the use of coincidence counters.[clarification needed] This unavoidably prevents superluminal communication since, even if a random or purposeful decision appears to be affecting events that have already transpired (as in the delayed choice quantum eraser), the signal from the past cannot be seen/decoded until the coincidence circuit has correlated both the past and future behavior. Thus the "signal" in the past is only visible after it is "sent" from the future, precluding quantum entanglement from being exploited for the purposes of faster-than-light communication or data time travel.
Does that mean if there were zero (or close to zero) "noise" ...faster than light (flt) transfer of information would be possible?
i.e. if the experiment was conducted in some dark & quite region of space-time...where only the entangled pairs were allowed strike the detectors (Ds and Dp)my first impression/conclusion is that:
1. the reason (i.e. flt is not possible due to noise) given above is somehow incorrect/incomplete
or
2. noise is some fundamental phenomena (tied to entanglement) that we don't fully understand yet
Assumption: the author assumes/believes FLT is not possible at all
Electromagnetic radiations are present throughout the Universe I doubt you'll find any place which is completely noise free.
ok...fine.
1. It does not need to be completely/100% noise free
2. however then our current understanding (and/or the above quote that i pasted) is saying:
well the information did arrive/travel FTL it's just that we cannot decode it
(i.e. we have to wait to compare both the photons, signal and idler)then we are saying...the EM radiation noise, not something fundamental, is preventing us from getting the information, otherwise the information did arrive FTL but needs to be decoded/filtered...
the reasoning does not sound robust/convincing
it's like saying the ball (with the information) did arrive FTL but its buried in the sand and to locate it in the sand will take time...and we need to compare with the other ball to determine its location
Cosidering the feasiblity of FTL communication (and not that of Ftl itself:-)),
then my friend what's the use if you can get information fast and not be able to use it.
from your post#1
"This unavoidably prevents superluminal communication since, even if a random or purposeful decision appears to be affecting events that have already transpired"
I think there is more than just noise that is preventing FTL. For one thing, I didn't think there was a way to even transmit information through entanglement. Is this incorrect? I thought everything was random.
Also, the coincidence counter is needed to determine which photons are entangled with which other photons. Without it all you get on one detector is just a stream of particles with random states or polarizations or whatnot. What meaning is there in that?
I don't think that 'noise' is the issue here; the issue is that the only 'information' you can send is 'randomly determined information' (probably an oxymoron under the standard definitions of terms); meaning that it's useless for most practical types of communication.
Imagine you owned a pair of dice that have a remarkable property: they are 'quantum linked' so that if you throw them both at the same time , the total score of two dice always equals 7. Imagine you give your friend one of the dice, he takes it a million miles away, and you both throw them. Now: if your friend sees a 2 on his die, he will 'instantly' learn that your die must read 5. But that's not really helpful for communication-- since you couldn't choose the signal that was sent.
It's not a perfect analogy but perhaps it gets the flavor across... also, I'm new here, so someone correct me if I'm wrong :) .
there is a way to get around the "randomly determined information", such as a DCQE experiment, where an eraser can be placed/removed at will to make it "purposeful determined information"
http://en.wikipedia.org/wiki/Delayed_choice_quantum_eraser
I agree that the DCQE seems to suggest a workaround for "purposeful determined information": one thinks, maybe the sender can "choose to erase or not", and the receiver will be able to observe the sender's choice? (i.e. 'erasing the which-path information' causes an interference pattern to be observed) Is that what you meant?
However I believe it can't work that way since the receiver doesn't actually have any good way to tell if the interference pattern is present or not! The receiver does not see an interference pattern ever on their "own" detector. Rather, they only detect interference as a statistical correlation between their own results and the sender's results. And therefore to realize that pattern exists, you need to ask the sender what they saw on their detector. And the only way to ask them is with 'normal' slower-than-light communication!
I think that's what the article is saying, here:
"The total pattern of signal photons at the primary detector never shows interference, so it is not possible to deduce what will happen to the idler photons by observing the signal photons alone"
and
"the interference pattern can only be seen retroactively once the idler photons have already been detected and the experimenter has obtained information about them"
and
rgmcc - good answer. to validate it, and understand this better, again let's look at various scenarios/tweaks to the DCQE experiment.
lets go with the walborn experiment, the link is below for the setup see page 7
http://arxiv.org/PS_cache/quant-ph/pdf/0106/0106078v1.pdf
the answers are at the end of the paper however they I am looking for answers with the below assumption
assume a highly hypothetical/impractical case where there is zero electromagnetic radiations, i.e. no stray photons/electrons, radio waves etc i.e. only entangled pairs striking the detectors
scenario 1 (no QWPs, no polarizer):
Without QWP1, QWP2 for signal photon and without polarizer for idler photon
a) what pattern we would see before co-incidence count/pairing?
b) what pattern we would see after co-incidence count/pairing?
scenario 2 (no QWPs, but polarizer):
Without QWP1, QWP2 for signal photon and with polarizer for idler photon
a) what pattern we would see before co-incidence count?
b) what pattern we would see after co-incidence count?
scenario 3 (QWPs, but No polarizer):
Without QWP1, QWP2 for signal photon and NO polarizer for idler photon
scenario 4 (QWPs, and polarizer):
Without QWP1, QWP2 for signal photon and polarizer for idler photon
assume a highly hypothetical/unpractical case where there is zero electromagnetic radiations, i.e. no stray photons/electrons, radio waves etc i.e. only entangled pairs striking the detectors
would not the receiver see an interference pattern on their "own" detector?
Assumption 1: I assumed that the QWPs would allow only select polarization thus no random polarizations
Assumption 2: I assumed that the polarizer (eraser) would allow only select polarization thus no random polarizations
Are both assumptions wrong or only 2nd assumption wrong?
  • · Replies 148 ·
16K
  • · Replies 41 ·
  • · Replies 58 ·
  • · Replies 18 ·
  • · Replies 63 ·
10K
