How can I refresh my memory on trigonometry for AP Physics?
  • Thread starter Thread starter jessicag
To refresh trigonometry knowledge for AP Physics, understanding the definitions of sine and cosine in right triangles is essential. The sine of an angle is the ratio of the opposite side to the hypotenuse, while the cosine is the ratio of the adjacent side to the hypotenuse. For the given problems, using these definitions allows for calculating the lengths of the sides of a triangle when one angle and the hypotenuse are known. Specifically, for a 26-degree angle with a hypotenuse of 11 cm, the opposite side can be found by multiplying 11 by the sine of 26 degrees, and the adjacent side by multiplying 11 by the cosine of 26 degrees. Mastering these concepts will aid in successfully tackling AP Physics challenges.
jessicag
Well i just got into ap physics.Its my senior year and my counsler thinks i should and can take it. I haven't even taken trig yet. It wouldn't work out with my schedule to take both. So i picked physics. Now that you know my story I would like some help to refresh my memory on stuff,
directions say:find the angles associated with the trig. equations below.
a.)sin. angle=.0872. i got .0015 but don't know if its right. and another question.
4.)one angle of a right triangle is 26 degrees.The hypotenuse is 11 cm. Calculate the lengths of the other two sides.(i have know idea what to do on this one) i would appriecate the help thank you ~~~~
Mathematics news on Phys.org
Well the second one is based on the definitions of sine and cosine. In a right triangle either one of the smaller two angles is made by the hypothenuse (the longest side) meeting one of the other sides. The shorter side is called the adjacent side of that angle. The third side of the triangle is called the opposite side for that angle. So now the sine of the angle is the opposite side divided by the hypontenuse. And the cosine of that angle is the adjactent side divided by the hypotenuse.
So in your problem you have sine (26o) = opp side/11
and cosine (26o} = adj side/11.
Or opp side = 11 times sine(26o),
adj side = 11 times cosine (26o)
Think you can take it from there?
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Suppose ,instead of the usual x,y coordinate system with an I basis vector along the x -axis and a corresponding j basis vector along the y-axis we instead have a different pair of basis vectors ,call them e and f along their respective axes. I have seen that this is an important subject in maths My question is what physical applications does such a model apply to? I am asking here because I have devoted quite a lot of time in the past to understanding convectors and the dual...
