Autocorrelation and pitch detection
Autocorrelation is a technique used in pitch detection by comparing an input waveform at various time intervals to identify periodic patterns. While it operates in the time domain, its application in detecting the fundamental frequency of an unknown source raises questions about practical implementation. The discussion highlights interest in using MATLAB for this purpose, emphasizing the need for detailed explanations rather than trivial responses. Resources such as the book "Digital Processing of Speech Signals" by Rabiner and Schafer, as well as online communities like music-dsp and comp.dsp, are suggested for further exploration. Understanding the practical implementation of summation in this context is also sought after.
sathya_rajan
I have heard that autocorrelation is used in pitch detection, but no proper or convincing explanation of how it is used. I had previously worked on echo removal using autocorrelation. But what puzzles me is that autocorrelation is done in time domain but how can this be used to detect fundamental frequency of some unknown source?
Go to www.google.com
Type in "autocorrelation pitch detection", hit the "I am feeling lucky" button.
Floid: I had done that before. The input waveform is compared (autocorrelated) at different time intervals. I don't know whether this can be implemented in practice. I am interested to perform this in matlab. If you have time, then you can explain. Please don't give trivial replies. Thank you.
also try joining the music-dsp mailing list or posting to the comp.dsp newsgroup.
also there is a book by Rabiner and Schafer Digital Processing of Speech Signals.
now, do you know how to implement a summation in practice?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
