Finding Points of Intersection for Polar Curves
jjeddy
I need to find the 2 points of intersection (in polar form) of the two curves.
I know just by looking that the origin will be one of the points, (0,0)
I have approached this two different ways,
1. set them equal to each other and tried to simplify.Which approach should i use?
OK, i used tanθ=sinθ/cosθ and i solved for θ
i can substitute back into get my corresponding (r,θ) r point and i should have my point right?
Right. That gives you one of the points. I'm not quite sure how you came up with your answer of θ=π/4 , so it's difficult to suggest how you should come up with the second point.
Is that right?I think that is my polar coordinate where it intersects
Your first post states that you need to find the 2 points of intersection.
For what other value of θ, is tan(θ) = 1 ? What is the period of the tangent function?
Prove $$\int\limits_0^{\sqrt2/4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx = \frac{\pi^2}{8}.$$ Let $$I = \int\limits_0^{\sqrt 2 / 4}\frac{1}{\sqrt{x-x^2}}\arcsin\sqrt{\frac{(x-1)\left(x-1+x\sqrt{9-16x}\right)}{1-2x}} \, \mathrm dx. \tag{1}$$ The representation integral of ##\arcsin## is $$\arcsin u = \int\limits_{0}^{1} \frac{\mathrm dt}{\sqrt{1-t^2}}, \qquad 0 \leqslant u \leqslant 1.$$ Plugging identity above into ##(1)## with ##u...
