Maximum jerk for experimental module
mtrc1
Maximum "jerk" for experimental module
1. A landing module has a mass M with three springs each of stiffness k that hover over the surface (height not given). If the final touchdown velocity is to be Vtd, what is the maximum jerk (time rate change of acceleration) the module experiences given a gravitational accerelation g during the time the springs are undergoing compression?
2. J = da/dt; F = k x. Also expect answer to occur when velocity is maximum
3. I have concluded that the module must free fall before the springs compress based on free oscillator relation x = A Cos(pt) + B Sin(pt) where p = Sqrt(k/m). It seems that this problem is missing info but an answer is given with only M, k, g, and Vtd values known. Any guidance is appreciated. Thx.
The maximum jerk experienced by the module can be calculated using the equation J = (F/m)*(Vtd/t), where F is the spring force, m is the mass of the module, Vtd is the final touchdown velocity and t is the time taken for the springs to compress. Using this equation, the maximum jerk can be calculated as:J = (k x / m) * (Vtd / t) where k is the spring constant, x is the distance the spring compresses, and t is the time taken for the springs to compress.
##|\Psi|^2=\frac{1}{\sqrt{\pi b^2}}\exp(\frac{-(x-x_0)^2}{b^2}).## ##\braket{x}=\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dx\,x\exp(-\frac{(x-x_0)^2}{b^2}).## ##y=x-x_0 \quad x=y+x_0 \quad dy=dx.## The boundaries remain infinite, I believe. ##\frac{1}{\sqrt{\pi b^2}}\int_{-\infty}^{\infty}dy(y+x_0)\exp(\frac{-y^2}{b^2}).## ##\frac{2}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,y\exp(\frac{-y^2}{b^2})+\frac{2x_0}{\sqrt{\pi b^2}}\int_0^{\infty}dy\,\exp(-\frac{y^2}{b^2}).## I then resolved the two...
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
