Sunlight equivalent light bulb
To replicate the average intensity of direct sunlight on a warm summer day, a full spectrum light bulb would need to generate between 700 to 1400 watts per square meter. Achieving this intensity requires a bulb with a significantly higher wattage, potentially in the thousands, to effectively simulate sunlight on nearby objects. Additionally, energy loss due to heat must be considered, which could affect overall performance. For accurate calibration of a photo sensor to sunlight intensity, exploring specialized photography forums may yield more practical advice. Finding a suitable bulb for such specific needs can be challenging, especially in areas with limited natural sunlight.
vinniewryan
If the 'average' intensity of direct sunlight on a warm summer day could be re-produced in a full spectrum light bulb, how many watts would that bulb be? I'm trying to find a bulb I can use to calibrate a photo sensor to sunlight intensity but my shop is on the base floor where there are no windows, and it's Seattle- no sunlight here.
I've searched google, all I get are light bulb ads. No useful info there.
Science news on Phys.org
You will need to generate between 700 - 1400 watts per square meter. The bulb itself would need to be many thousands of watts to simulate sunlight on an object very close to it. Also keep in mind any energy lost to heating up the bulb.
you may be better off joining a photography forum :smile:
I would like to use a pentaprism with some amount of magnification. The pentaprism will be used to reflect a real image at 90 degrees angle but I also want the reflected image to appear larger. The distance between the prism and the real image is about 70cm. The pentaprism has two reflecting sides (surfaces) with mirrored coating and two refracting sides. I understand that one of the four sides needs to be curved (spherical curvature) to achieve the magnification effect. But which of the...
