bcrowell said:
Yes. The c in relativity shouldn't really be interpreted as having anything to do with light. It's a universal speed that is the same in all frames of reference. Massless things, including gravity waves and light waves, all move at this speed.
Then how do you explain gravitational waves? They are measured in a change of amplitude of the gravity, not frequency. Frequency is the only way light can change from a moving source. And, a change of amplitude can only mean that the peaks and valleys from the gravity are overlapping, which can only mean that the gravity speed coming from a moving source is not reference frame independent because the actual peaks and valleys are overlapping and increasing in amplitude. Isn't this correct? If not, please explain.
BUT...
Ok, a change here: I found on Wikipedia that the amplitude "is not the quantity which would be analogous to what is usually called the amplitude of an electromagnetic wave"
So maybe I am making an invalid comparison? HOWEVER...
It also says on Wikipedia: "Speed: This is the speed at which a point on the wave (for example, a point of maximum stretch or squeeze) travels. For gravitational waves with small amplitudes, this is equal to the speed of light, c."
http://en.wikipedia.org/wiki/Gravitational_wave"
So what happens to the speed when the amplitudes are not small? And what is "small" defined as? And if the amplitude of a gravitational wave is not like light, then what is it?
Thanks for your patience!
Jake
