How does a salt bridge prevent charge buildup in a galvanic cell?
A salt bridge in a galvanic cell prevents charge buildup by allowing ions to flow between the two half-cells, maintaining electrical neutrality. Without it, the charge difference created by electron flow would hinder further electron movement, as electrons would be removed from the positively charged side and added to the negatively charged side. This process is energetically unfavorable according to Coulomb's Law, which states that work must be done against the opposing forces. The salt bridge thus enables continuous electron flow and sustains the cell's operation. Overall, it is essential for the efficient functioning of galvanic cells.
gkangelexa
As electrons leave one half of a galvanic cell and flow to the other, a difference in charge is established. If no salt bridge were used, this charge difference would prevent further flow of electrons.
Why would the charge difference prevent further flow of electrons ??
Because you'd be taking electrons away from the side that's already positively charged, and adding them to the side that's already negatively charged. By Coulomb's Law both of these are energetically unfavourable (i.e., to do them you have to do work against a force pushing the opposite way).
Thread 'Gauss' law seems to imply instantaneous electric field propagation'
Imagine a charged sphere at the origin connected through an open switch to a vertical grounded wire. We wish to find an expression for the horizontal component of the electric field at a distance ##\mathbf{r}## from the sphere as it discharges. By using the Lorenz gauge condition: $$\nabla \cdot \mathbf{A} + \frac{1}{c^2}\frac{\partial \phi}{\partial t}=0\tag{1}$$ we find the following retarded solutions to the Maxwell equations If we assume that...
Thread 'Griffith, Electrodynamics, 4th Edition, Example 4.8. (First part)'
I am reading the Griffith, Electrodynamics book, 4th edition, Example 4.8 and stuck at some statements. It's little bit confused. > Example 4.8. Suppose the entire region below the plane ##z=0## in Fig. 4.28 is filled with uniform linear dielectric material of susceptibility ##\chi_e##. Calculate the force on a point charge ##q## situated a distance ##d## above the origin. Solution : The surface bound charge on the ##xy## plane is of opposite sign to ##q##, so the force will be...
Dear all, in an encounter of an infamous claim by Gerlich and Tscheuschner that the Greenhouse effect is inconsistent with the 2nd law of thermodynamics I came to a simple thought experiment which I wanted to share with you to check my understanding and brush up my knowledge. The thought experiment I tried to calculate through is as follows. I have a sphere (1) with radius ##r##, acting like a black body at a temperature of exactly ##T_1 = 500 K##. With Stefan-Boltzmann you can calculate...
