How Do You Use a Transistor in a Circuit?
Transistors are widely recognized as essential electronic switches used in circuits. To effectively incorporate a transistor, one must understand how to control its switching mechanism. Resources such as HowStuffWorks and Wikipedia provide foundational knowledge about transistors and their functions. Additionally, "The Art of Electronics" by Horowitz and Hill is recommended for a deeper understanding of electronics. Overall, these resources can significantly enhance comprehension of transistor applications in circuits.
alpine2beach
I'm pretty sure that one of the most common electronic switches is the transistor. That being said, I'm not very sure of how you can incorporate one into a circuit. Basically, what I'm asking is, how do I get it to switch when I want it to? How do I use a transistor?
What do you know about transistors?
How do you think they function
do a google search for transistors as switch and see what you come up with. There is a lot of relevant information there.
(I've been taking notes Berkeman) :)
:smile:
Here are a couple intro articles on transistors:
at HowStuffWorks.com http://www.howstuffworks.com/transistor.htm
at Wikipedia.org http://en.wikipedia.org/wiki/Transistor
Also, if you'd like to learn more about electronics, take a look at the book "The Art of Electronics" by Horowitz and Hill. Your high school library may have a copy (if not, ask them to order it), or your city library may have a copy. It's a pretty easy read, and you can learn lots of useful things about electronics from it.
Thank you so freaking much! Wikipedia is pretty useless if you don't already know something about electronics, but that link to HowStuffWorks was definitely the most simple explanation of a transistor that I have ever read! Also, thanks for the book, I'll have to check it out. Thanks again!
Hi all I have some confusion about piezoelectrical sensors combination. If i have three acoustic piezoelectrical sensors (with same receive sensitivity in dB ref V/1uPa) placed at specific distance, these sensors receive acoustic signal from a sound source placed at far field distance (Plane Wave) and from broadside. I receive output of these sensors through individual preamplifiers, add them through hardware like summer circuit adder or in software after digitization and in this way got an...
I have recently moved into a new (rather ancient) house and had a few trips of my Residual Current breaker. I dug out my old Socket tester which tell me the three pins are correct. But then the Red warning light tells me my socket(s) fail the loop test. I never had this before but my last house had an overhead supply with no Earth from the company. The tester said "get this checked" and the man said the (high but not ridiculous) earth resistance was acceptable. I stuck a new copper earth...
I am not an electrical engineering student, but a lowly apprentice electrician. I learn both on the job and also take classes for my apprenticeship. I recently wired my first transformer and I understand that the neutral and ground are bonded together in the transformer or in the service. What I don't understand is, if the neutral is a current carrying conductor, which is then bonded to the ground conductor, why does current only flow back to its source and not on the ground path...
