Do Vptp and Vmax mean the same thing?
  • Thread starter Thread starter Femme_physics
    Mean
Vptp does not mean the same as Vmax; Vptp refers to voltage peak-to-peak, while Vmax indicates the maximum voltage from zero to the peak. In a sine wave, Vmax is the voltage measured from the zero line to the peak value. Conversely, Vp-p measures the total voltage from the positive maximum to the negative maximum, which is twice the value of Vmax. This distinction clarifies the difference between the two voltage measurements. Understanding these terms is essential for accurate electrical analysis.
Femme_physics
Question at topic title.
Does Vptp mean V peak to peak?
If so, no it isn't the same as Vmax.
If it was a sinewave, Vmax would be the voltage from the zero line to the peak value.
Vp-p would be the voltage from the positive maximum to the negative maximum or twice the voltage of Vmax.
Ah, makes sense. Thank you!
Hey guys. I have a question related to electricity and alternating current. Say an alien fictional society developed electricity, and settled on a standard like 73V AC current at 46 Hz. How would appliances be designed, and what impact would the lower frequency and voltage have on transformers, wiring, TVs, computers, LEDs, motors, and heating, assuming the laws of physics and technology are the same as on Earth?
While I was rolling out a shielded cable, a though came to my mind - what happens to the current flow in the cable if there came a short between the wire and the shield in both ends of the cable? For simplicity, lets assume a 1-wire copper wire wrapped in an aluminum shield. The wire and the shield has the same cross section area. There are insulating material between them, and in both ends there is a short between them. My first thought, the total resistance of the cable would be reduced...
I used to be an HVAC technician. One time I had a service call in which there was no power to the thermostat. The thermostat did not have power because the fuse in the air handler was blown. The fuse in the air handler was blown because there was a low voltage short. The rubber coating on one of the thermostat wires was chewed off by a rodent. The exposed metal in the thermostat wire was touching the metal cabinet of the air handler. This was a low voltage short. This low voltage...
