I'm a bit unclear about how you are setting up what you call your "point of interesection" equations. But you can do this:
You know that the common normal vector for the parallel planes is < 2, 2, -1 >. Pick a point in the plane 2x + 2y - z = 1 ; we can make this easy and use ( 0, 0, -1 ). Then this normal line passing through the chosen point has the vector equation
< x, y, z > = < 2t , 2t, -t - 1 > .
This line intersects the second plane for 4x + 4y - 2z = 5 , or
4 · 2t + 4 · 2t - 2 ( -t - 1 ) = 5 --> 18t + 2 = 5 ---> t = 1/6 .
The point of intersection in that plane is then ( 2 · 1/6 , 2 · 1/6 , -1/6 - 1 ) = ( 1/3 , 1/3 , -7/6 ). The distance between the two points along this line mutually perpendicular to the two planes (what is called the "perpendicular distance", the shortest distance between the planes) is given by
\sqrt{ ( \frac{1}{3} - 0 )^{2} + ( \frac{1}{3} - 0 )^{2} + ( -\frac{7}{6} - [-1] )^{2} } = \sqrt{ ( \frac{1}{3} )^{2} + ( \frac{1}{3} )^{2} + ( -\frac{1}{6} )^{2} } = \sqrt{ \frac{1}{9} + \frac{1}{9} + \frac{1}{36} }
= \sqrt{ \frac{4 + 4 + 1}{36} } = \sqrt{ \frac{9}{36} } = \frac{1}{2} .
I think the problem you may have made for yourself is that you didn't actually choose a point of intersection in either plane to build a normal line from.
A more general argument along these lines gives the perpendicular distance between two parallel planes ax + by + cz = d1 and ax + by + cz = d2 as D = \frac{\vert d_{1} - d_{2} \vert}{\sqrt{a^{2} + b^{2} + c^{2} } } . For this problem, we would write
2x + 2y - z = 1 and 2x + 2y - z = 5/2 ;
The square root in the denominator gives 3 and the absolute value of the difference in the numerator is 3/2 , so the formula yields D = (3/2) / 3 = 1/2 .
