Is it possible to have negative joules?
  • Level: High School
  • Thread starter Thread starter DB
    Joules Negative
6 replies · 28K views
DB
Is it possible to have a negative joule?
Not sure what you are really asking, but the joule is a unit of energy or work. So, is it possible to have a negative energy or do negative work? Yes.
Ya that's what I meant, so what would be an example of a Negative Energy/Work
Thanks
Two random examples:
The work done to stop a car (by applying the brakes) is negative work since the force and displacement are opposite.
If you take the top of a hill as your reference (zero) point, then the gravitational potential energy of an object at the bottom of the hill would be negative.
And don't forget that usually what is interesting is the change in energy. And that can certainly be negative.
another interesting example depends on which way two (oppositely) charged particles are rotating around each other, i.e. clockwise or anticlockwise. we have either negative or positive potential energy
Negative energy or work arises from comparing one statepoint to some reference.
Think of temperature scales, such as Centrigrade and Fahrenheit. They both have negative temperatures. But when we consider temperatures in the Kelvin and Rankine scales - with absolute zero as the reference - the temperatures are always positive.
Compared to absloute zero (correct me if I am wrong), everything has positive energy.
Negative energy is a 'relative' term.
One could ask is there such a thing as negative mass. As far as I know, mass is always positive.
Which reminds me of solving the diffusion equation for neutron flux in a reactor. One could select a function and boundary conditions that would give the possibility of a negative flux (or negative numbers of neutrons passing through a unit area per unit time). But a negative number of neutrons does not make sense physically - and a such a solution would clearly be wrong.
