Particle in semi infinite potential well
leonne
particle moving in the semi infinite potentail well set up and solve SE for the system assume E<Vo
(-h2/2m) d2\psi/dx2 +v(x)\psi=E\psi
so in reagion one its infinite so \psi=0. reagion 2 is what i am confused about. looking throught the book i saw the gen solution for inside the well to be \psi=Ae(ikx)+Be-(ikx) but for this problem its Acos(kx)+Bsin(kx)
in the book does not really show how it finds the gen solution. I am just a little confused on how you would solve the SE well i know for inside v=0 and i plug that into SE and from that the book just goes to the gen solution
thanks
edit after looking at lecture note i see he uses the cos for the inside , but in they book for the same infinite pot well they use the e^ are they the same?
The solutions are equivalent. They're just being expressed in different bases.
\begin{align*}
A e^{ikx} + B e^{-ikx} &= A(\cos kx+i\sin kx)+B(\cos kx-i\sin kx) \\
&= (A+B)\cos kx + i(A-B)\sin kx \\
&= C \cos kx + D \sin kx
\end{align*}Since A and B are arbitrary constants, C=A+B and D=i(A-B) are as well.
o ok thxs
Hello everyone, I’m considering a point charge q that oscillates harmonically about the origin along the z-axis, e.g. $$z_{q}(t)= A\sin(wt)$$ In a strongly simplified / quasi-instantaneous approximation I ignore retardation and take the electric field at the position ##r=(x,y,z)## simply to be the “Coulomb field at the charge’s instantaneous position”: $$E(r,t)=\frac{q}{4\pi\varepsilon_{0}}\frac{r-r_{q}(t)}{||r-r_{q}(t)||^{3}}$$ with $$r_{q}(t)=(0,0,z_{q}(t))$$ (I’m aware this isn’t...
Hi, I had an exam and I completely messed up a problem. Especially one part which was necessary for the rest of the problem. Basically, I have a wormhole metric: $$(ds)^2 = -(dt)^2 + (dr)^2 + (r^2 + b^2)( (d\theta)^2 + sin^2 \theta (d\phi)^2 )$$ Where ##b=1## with an orbit only in the equatorial plane. We also know from the question that the orbit must satisfy this relationship: $$\varepsilon = \frac{1}{2} (\frac{dr}{d\tau})^2 + V_{eff}(r)$$ Ultimately, I was tasked to find the initial...
