What are the conditions for non-integer exponents to be single valued?
Non-integer exponents can lead to multi-valued expressions, particularly in complex analysis. The discussion highlights the need for specific conditions under which these exponents can be treated as single-valued. It emphasizes that the initial equation presented is incorrect and suggests that there are no universal conditions that allow non-integer exponents to be single-valued. Further exploration in the field of complex functions may provide clarity on this issue. Understanding these principles is crucial for accurate mathematical modeling involving non-integer exponents.
Black Integra
Nothing much, I have this:
gif.latex?\dpi{150}%20e^\theta=(e^{i\theta})^{-i}=(e^{i(\theta+2\pi)})^{-i}=e^{\theta+2\pi}.gif
I have studied (myself) about this for many days.
And I believe that, for some conditions
for a complex ψ,ϕ
What are those conditions I mentioned about? And which field of study I should go to see?
Mathematics news on Phys.org
Your first equation is obviously wrong, as you can see. For the second question, there are no conditions where it doesn't hold.
The problem lies in the fact that for non-integer exponents, the expression is not single valued.
Thread 'Video on imaginary numbers and some queries'
Hi, I was watching the following video. I found some points confusing. Could you please help me to understand the gaps? Thanks, in advance! Question 1: Around 4:22, the video says the following. So for those mathematicians, negative numbers didn't exist. You could subtract, that is find the difference between two positive quantities, but you couldn't have a negative answer or negative coefficients. Mathematicians were so averse to negative numbers that there was no single quadratic...
Insights auto threads is broken atm, so I'm manually creating these for new Insight articles. In Dirac’s Principles of Quantum Mechanics published in 1930 he introduced a “convenient notation” he referred to as a “delta function” which he treated as a continuum analog to the discrete Kronecker delta. The Kronecker delta is simply the indexed components of the identity operator in matrix algebra Source: https://www.physicsforums.com/insights/what-exactly-is-diracs-delta-function/ by...
Thread 'Unit Circle Double Angle Derivations'
Here I made a terrible mistake of assuming this to be an equilateral triangle and set 2sinx=1 => x=pi/6. Although this did derive the double angle formulas it also led into a terrible mess trying to find all the combinations of sides. I must have been tired and just assumed 6x=180 and 2sinx=1. By that time, I was so mindset that I nearly scolded a person for even saying 90-x. I wonder if this is a case of biased observation that seeks to dis credit me like Jesus of Nazareth since in reality...
10K
