Nomenclature of Organic Compounds: Significance of -#-yl and E/Z Isomerism
  • Thread starter Thread starter newyorkcity
    Compounds Organic
The discussion centers on the nomenclature of organic compounds, specifically the significance of the suffix -5-yl in bicyclo[2,1,0]pent-5-ylbicyclo[3,3,0]octane, indicating the carbon on the bicyclo subunit that connects to the main compound. It clarifies that the -#-yl notation denotes the attachment point on the bicyclic structure, with the example showing that the connection is made one carbon over from the bridgehead. Additionally, the use of (E) in (E)-1,2-diiodo-1-methylcyclohexane is confirmed to indicate a trans configuration, while Z would indicate cis, with both iodine atoms positioned axially. The analysis concludes with a request for confirmation of this understanding. Overall, the discussion effectively clarifies the nomenclature and structural implications in organic chemistry.
newyorkcity
Hi all,
I have a question regarding the nomenclature of organic compounds. What is the significance of -5-yl in
? In general, what is the significance of the # in -#-yl in compounds?
Additionally, in (E)-1,2-diiodo-1methylcyclohexane, does the E indicate trans, whereas a Z would indicate cis? As in the two iodine atoms are on the first and second carbons, and they are both trans to each other (both axial)?
Thanks guys!
Chemistry news on Phys.org
I think I figured this out. So I think the -#-yl (when used with bicyclo subunits) denotes the carbon on the subunit that attaches to the main compound.
In the case presented above, the bicyclo[2,1,0]pentyl is not attached via a bridgehead C but rather one C over, but since the 'cyclopropyl' side is attached to the bicyclo[3,3,0]octane, we need to first go around the larger 'cyclobutyl' portion of the bicyclo[2,1,0]pentyl, thus getting a -5-yl. Note that I am using 'cyclobutyl' and 'cyclopropyl' as rough descriptors of the portions of the bicyclo[2,1,0]pentyl I am trying to reference; I can't think of a better way to accomplish this without an image.
Similarly, if we had 5-methylbicyclo[3,3,0]oct-2-yl-4-methylnonane, this would indicate that there is a methyl on the bridgehead of methylbicyclo[3,3,0]oct-2-yl and the bond to the main nonane chain is on the second carbon (one over from the bridgehead carbon) of the methylbicyclo[3,3,0]oct-2-yl.
Can someone confirm this analysis?
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
