Comparing Gravity in Newtonian and Relativistic Frameworks
John15
I understand there is a slight difference in the value of gravity when worked out using Newton or relativity. The obvious example being mercury where Newtonian is slightly out and relativity accurate.
Does relativity show a higher or lower figure or does the difference in working out mean you cannot compare the 2.
The only effect you can directly compare it the gravitational acceleration. Here is a thread about it:
https://www.physicsforums.com/showthread.php?t=310397
But GR predicts other effects that also affect trajectories like time dilation and space distortion.
Why do Newtons equations not correctly describe the orbit of mercury. How precise are they with the other orbits.
Newton's theory is pretty accurate already, the error is only about 1 part in 107.
The perihelion shift applies to all non circular orbits but the effect is largest for Mercury because Mercury is closest to the Sun.
We can actually express equatorial orbits in common form both for GR and Newton's theory:
\Large {\frac {{d}^{2}u}{{d\varphi }^{2}}}=1/2\,\mbox {D} \left( f \right) <br /> \left( u \right) <br />
Where f(u) is:
\Large f \left( u \right) =2\,{\beta}^{2}u+2\,k-{u}^{2}<br />
for Newton and
f(u) is:
\Large f \left( u \right) =2\,{\beta}^{2}u+2\,k-{u}^{2}+2\,{u}^{3}<br />
for GR.
The only difference is an extra term (u is defined here as m/r).
For details see for instance "General Relativity" - Woodhouse, chapter 8.2
With a lot of hand waving we get an approximate advance of:
\Large 6\,{\frac {Gm\pi}{r_{{0}}{c}^{2}}}<br />
where r0 is the approximate radius.
Have looked at the other thread, I personally don't like the cone idea, it is similar to the rubber sheet example unfortunately for me it does not work in 3d space all the cones cancel out leaving a series of expanding spheres and, for example, the Earth ofbits the suns equator not around its top.
Out of interest if the distance in Newton was taken from the shwartzchild radii rather than exact centers would it bring Newton and einstein any closer, it would obviously slightly increase g in Newton especially close to a large body like the sun.
Not sure if the +2u3 above causes an increase or decrease in GR.
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
