Michelson-Morley experiment doubts
  • Thread starter Thread starter Highwaydude
    Doubts Experiment
Highwaydude
Hello, I am newly learning special relativity. I have this particular doubt>
Why is light moving along the hypoteneuse of the triangle while we are moving the apparatus?
(Its not like it has a horizontal component of velocity which is equal to the velocity of the apparatus).
Why do you think you know how light is moving?
If you know, you need to let the rest of us know, because you have information that nobody else has.
Highwaydude, A light beam aimed vertically in the moving frame will be seen to have a horizontal component in the stationary frame. If if did not, it would fail to hit the mirror.
Sorry for replying late.. yes after a bit of thinking I've figured it out, like you said, since the apparatus is moving we are seeing it as if it moves along an angle. :)
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
From $$0 = \delta(g^{\alpha\mu}g_{\mu\nu}) = g^{\alpha\mu} \delta g_{\mu\nu} + g_{\mu\nu} \delta g^{\alpha\mu}$$ we have $$g^{\alpha\mu} \delta g_{\mu\nu} = -g_{\mu\nu} \delta g^{\alpha\mu} \,\, . $$ Multiply both sides by ##g_{\alpha\beta}## to get $$\delta g_{\beta\nu} = -g_{\alpha\beta} g_{\mu\nu} \delta g^{\alpha\mu} \qquad(*)$$ (This is Dirac's eq. (26.9) in "GTR".) On the other hand, the variation ##\delta g^{\alpha\mu} = \bar{g}^{\alpha\mu} - g^{\alpha\mu}## should be a tensor...
