Find the limit of x^2(√(x^4+5)-x^2) as x->∞
  • Thread starter Thread starter NWeid1
    Limit
The limit of x^2(√(x^4+5)-x^2) as x approaches infinity can be evaluated without L'Hospital's Rule, as it does not present an indeterminate form suitable for that method. Instead, multiplying the expression by a conjugate, (√(x^4 + 5) + x^2)/(√(x^4 + 5) + x^2), is suggested to simplify the limit. This approach transforms the expression into a more manageable form for analysis. The limit ultimately resolves to a specific value as x approaches infinity. Understanding the proper techniques for evaluating limits is crucial for tackling similar problems effectively.
NWeid1
Find the limit of x^2(√(x^4+5)-x^2) as x->∞. I think it might be a L'Hospitals rule, but I'm not sure. We haven't done many problems like this yet, thanks!
L'Hospital's Rule is valid only for certain indeterminate forms, like infinity/infinity or 0/0.
You should be able to determine this limit by inspection.
Right. L'Hopital's Rule is not applicable here.
I don't know about that. This limit is another of the indeterminate forms - [∞ * 0].
I would multiply the expression in the limit by 1, in the form of \sqrt{x^4 + 5} + x^2 over itself.
I tried to combine those 2 formulas but it didn't work. I tried using another case where there are 2 red balls and 2 blue balls only so when combining the formula I got ##\frac{(4-1)!}{2!2!}=\frac{3}{2}## which does not make sense. Is there any formula to calculate cyclic permutation of identical objects or I have to do it by listing all the possibilities? Thanks
