Dutasteride powder dissolved in ethanol/vodka for topical
  • Thread starter Thread starter dutaboy83
    Powder
Dutasteride, a hair loss medication, is soluble in ethanol but not in water, which raises concerns about its dissolution in a vodka solution. The user is attempting to dissolve 500mg of dutasteride in 100ml of vodka (40% ethanol), but is experiencing undissolved particles. Suggestions include using a higher concentration of ethanol, such as 90% ethanol or Everclear, to enhance solubility. Additionally, incorporating essential oils like orange or lemon oil may help improve dissolution. The presence of water in vodka is likely contributing to the solubility issue. Heating the solution could also be a potential solution to achieve complete dissolution.
dutaboy83
Hi there!
Hopefully someone is here who could help me with this!
For a project I want to make a topical of a hairloss medicine. It's about Dutasteride.
Dutasteride is soluble in ethanol (44 mg / mL), methanol (64 mg / mL) and polyethylene glycol 400 (3 mg / mL), but insoluble in water.
For a solution, I use vodka (40% ethanol). I want to put 5mg dutasteride in 1ml of wodka.
A solution is now made for 100 days: 100 ml (vodka, 40%, so 40ml ethanol) and 500mg dutasteride.
This is now in a jar and I have stirred, shaken, etc., but not all of the dutasteride is dissolved in the solution. You keep seeing bits and dots floating around.
I really want the 500mg to perfectly dissolve in 100ml vodka, so that each dose of 1ml remains the same ...
Does anyone know how to solve this? Is it perhaps because dutasteride is not soluble in water? And vodka contains some water? Or is it neccesary to heat up the solution?
Hopefully someone knows how to help me!
Thank you very much in advance!
Greetings!
Chemistry news on Phys.org
You already have data for ethanol solubility, so you use more highly concentrated ethanol. The best way is to use 90 percent ethanol, so add measured amount of this concentrated ethanol until your solute dissolves.
Right, you should have used Everclear instead of cheap (I hope) vodka. You might get more to go into vodka solution if you add an essential oil like orange oil or lemon oil. Hmmm, if only vodka came already flavored with citrus oils!
I want to test a humidity sensor with one or more saturated salt solutions. The table salt that I have on hand contains one of two anticaking agents, calcium silicate or sodium aluminosilicate. Will the presence of either of these additives (or iodine for that matter) significantly affect the equilibrium humidity? I searched and all the how-to-do-it guides did not address this question. One research paper I found reported that at 1.5% w/w calcium silicate increased the deliquescent point by...
