Calculating Displacement and Speed in a Standing Wave on a String
Adjacent antinodes of a standing wave on a string are 14.5 cm apart, with a particle at an antinode oscillating with an amplitude of 0.850 cm and a period of 0.08 s. The displacement of a point on the string can be calculated using the formula A*cos(2πt/T)*sin(2πx/(2s)), yielding a result of 3.25 x 10^(-3) m. The speed of propagation of the transverse wave is determined using v = λf, resulting in a speed of 1.81 m/s. To find the amplitude at a point 3.20 cm to the right of the antinode, the same displacement formula is applied, leading to the amplitude expression involving cosine and sine functions. This discussion highlights key calculations for understanding standing waves on a string.
Lakers08
Adjacent antinodes of a standing wave on a string are a distance 14.5 cm apart. A particle at an antinode oscillates in simple harmonic motion with amplitude 0.850 cm and period 8.00×10-2 s . The string lies along the + x - axis and is fixed at x = 0.
Find the displacement of a point on the string as a function of position and time.
Find the speed of propagation of a transverse wave in the string.
Find the amplitude at a point a distance 3.20 to the right of an antinode.
- the first question was pretty easy easy i just used the formula :
A*cos(2*pi*t/T)*sin(2*pi*x/(2*s)) T = period A = amplitude
and i got the result: 3.25*10^(-3)m. which is correct, now can anybody give me any clues on how to calculate the speed of the propagation and the amplitude at 3.20 to the right of the antinode?
if i remember correctly
v = \lambda f
v = \frac{w}{k}
For the third question you know an atinode is located at a distance of \frac{\lambda}{4} so x = \frac{\lambda}{4} + 3.2
Also
k = \frac{2 \pi}{\lambda}
Remember Stationary waves formula
y = (2A \sin kx) \cos \omega t
To calculate the speed of propagation, we can use the formula v = λf, where v is the speed, λ is the wavelength, and f is the frequency. In this case, the wavelength is equal to the distance between adjacent antinodes, which is 14.5 cm (0.145 m). The frequency can be calculated using the formula f = 1/T, where T is the period given in the problem. Plugging in the values, we get f = 1/8.00×10-2 s = 12.5 Hz. Now, we can calculate the speed using v = 0.145 m * 12.5 Hz = 1.81 m/s.
To find the amplitude at a point 3.20 cm to the right of the antinode, we can use the formula A*cos(2*pi*t/T)*sin(2*pi*x/(2*s)). In this case, the value of x is 0.032 m (3.20 cm converted to meters) and all the other values remain the same. Plugging in these values, we get A*cos(2*pi*t/T)*sin(2*pi*0.032/(2*0.145)) = 0.850*cos(2*pi*t/8.00×10-2)*sin(2*pi*0.032/0.290) = 0.850*cos(25*pi*t)*sin(0.219*pi). This is the amplitude at a point 3.20 cm to the right of the antinode.
