Speed of light between a source and target moving wrt to each other
Passionflower
How much experimental evidence is there that the speed of light stays c between a source and target moving wrt to each other?
None.
The idea that the speed of light might depend on the velocity of the source was known as emission theory. It was tested by the Alvager experiment, in which 6 GeV neutral pions were allowed to decay in flight: π0 → γ + γ. The photons were then timed over a flight path of about 30 m, and the result was that the velocity of the photons was within 10-4 of c.
I'm wondering if that might be an over-generalization. Won't emission theory specifically be the case where the velocity of the emitting particle is added to the nominal propagation velocity?
Other theories might exist where the velocity of the source affects the local speed of light without necessarily adding linearly to the nominal propagation velocity c. If such effects are reciprocal in the sink then they may cancel leaving a perceived velocity c (which could indicate a deficiency for physics modeling the perceived effects in comparison to physics modeling the underlying effects).
OK, so this has bugged me for a while about the equivalence principle and the black hole information paradox. If black holes "evaporate" via Hawking radiation, then they cannot exist forever. So, from my external perspective, watching the person fall in, they slow down, freeze, and redshift to "nothing," but never cross the event horizon. Does the equivalence principle say my perspective is valid? If it does, is it possible that that person really never crossed the event horizon? The...
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
